latigid on Posted October 14, 2015 Author Posted October 14, 2015 Thanks for the tip, originally I had 5 extra RNs in. For the transistor/resistor pairs, what short do you mean? Short to ground? You might have to upload photos. Note that the bottom right transistor pin should be connected to ground. All 74HC165 inputs have a pullup to 5V. Please check carefully around this pin, is the solder mask scratched? If you try to reflow the solder it can help.
tashikoma Posted October 14, 2015 Posted October 14, 2015 sorry for the debug...i take all the time to build cool it with optimum conditions... more than 30hours (Thorsten is a god , a robot or the god of robots to manage it in 15h)since the problem i reflow many times...!for the resistor/transistor pairs:there are a shortcut between each resistor pad (resistor was 0.2 ohm value) without the components short is present! no solder mask scratchedfor the 74hc165 pin 6 is shorted to ground or 5v because i've got a short between 5v and ground (when mesuring between 5v and ground at J3: 0,2ohm)i've change this IC and it's the same...
latigid on Posted October 15, 2015 Author Posted October 15, 2015 Okay, well I'm on holiday at the moment, so I won't be able to remote debug very easily. Even with a short on this resistor it would only kill that particular section and not the whole 5V line. 5V short could be anywhere on the board, not necessarily at that IC. Check the vias and mounting holes too.Bonne chance!
Altitude Posted October 20, 2015 Posted October 20, 2015 Question to anyone who's finished: whats the max current draw?
tashikoma Posted October 21, 2015 Posted October 21, 2015 2 mA per led if there are all illuminated (that will never arrive in normal use) result 1156 mA so 1,2A (i can't mesure it cause bugged)1.2A is security value and not the real consumption wich will be less than 1A.i receive the case today , beautifull and look very strong!
latigid on Posted October 22, 2015 Author Posted October 22, 2015 (edited) I don't have my unit here to test, it's at a friends awaiting a few modifications (my case had fewer standoffs so needs mechanical strengthening). TK. should be able to give you an idea of current draw with all LEDs lit, probably he has a nice bench supply running :).Perhaps a small caution to check the board for errors before starting. They have been electrically tested but there's a remote possibility of unmasked ground plane which could give a short if covered with a lot of solder. I have a few spares here which I will go over carefully when the light is better, will let you know if I find anything. Edited October 22, 2015 by latigid on
latigid on Posted October 22, 2015 Author Posted October 22, 2015 (edited) Here are a few images of the side in case you want to make wooden end cheeks. Dimensions are in inches, please check them against your case to be sure.temporary base.DWGtemporary base.DXFtemporary base.EDRW EDIT: suppose you could make some metal flange rack ears too! Oh, these screw threads are 6-32 and all screws are stainless steel so the aluminium parts should last for a very long time. Edited October 22, 2015 by latigid on
Rowan Posted October 23, 2015 Posted October 23, 2015 I'm going to be ordering the button spacer in the next week or so. Is there anyone in the UK that also needs the spacer so we can split the shipping cost?
tashikoma Posted October 24, 2015 Posted October 24, 2015 (edited) for information it fits the BLM case Midi hole:https://www.reichelt.com/Diode-Jacks/DIO-80SN-EMS/3/index.html?&ACTION=3&LA=2&ARTICLE=46282&GROUPID=5182&artnr=DIO-80SN+EMS Edited October 24, 2015 by tashikoma
Phatline Posted October 28, 2015 Posted October 28, 2015 (edited) i dont find the the link to the button spacer? monoko? BOM? Help.edit: found it in the first post.... *`.eps Edited October 28, 2015 by Phatline
TK. Posted October 28, 2015 Posted October 28, 2015 Here some amphetamine for those who haven't built their case yet! :-)Note that I added some enhancements & fixes to the MBSEQ firmware while working on this demo (demos are always a good possibility for me to doublecheck that everything is working as expected!). The changes are already in the SVN repository and will be released soon.Best Regards, Thorsten.
Altitude Posted October 28, 2015 Posted October 28, 2015 So just to confirm: quad IIC blm port connects to J5B on the STM32F4 core?
CJ55 Posted October 29, 2015 Posted October 29, 2015 So just to confirm: quad IIC blm port connects to J5B on the STM32F4 core?I think, that's an error in the description of the MB CORE_STM32F4. You have to use one of the four MIDI I/Os at J11E.MIDI at J5B is only provided on older COREs.
latigid on Posted October 29, 2015 Author Posted October 29, 2015 Here some amphetamine for those who haven't built their case yet! :-)Note that I added some enhancements & fixes to the MBSEQ firmware while working on this demo (demos are always a good possibility for me to doublecheck that everything is working as expected!). The changes are already in the SVN repository and will be released soon.Best Regards, Thorsten.TK.: very nice! It looks like the slider implementation is very good. I guess you kept the longer sliders in? This will be a personal preference I suppose. An idea I had was to make or buy some silicone covers to use as slider caps. This might make them a bit more ergonomic and also act as diffusers for the LEDs which can be quite bright. I take it that there's no issues with the case? Stability (i.e. no PCB flex) is good with the extra standoffs? Are all M2 grub screws installed? Do the bottom feet work? Next up will be to connect up extra expression pedals, CV inputs etc. :) (another DIN connector?) So just to confirm: quad IIC blm port connects to J5B on the STM32F4 core?The BLM/quad IIC schematic always gives me a headache :). My approach was to harvest old PC cables (with single or dual female pin sockets, could also crimp new ones) that connected all of the front switches, LEDs etc. to the motherboard, and join them with an IDC10. I'm still using the F1 Core, but luckily I have a breakout board which also separates MIDI IO 3. If you have an older Core8 you can always swap out this for the miniCore during testing, just use temporary clips on the MIDI outs. You need to supply power to the BLM, and please don't send data without the main board powered up.
Altitude Posted October 29, 2015 Posted October 29, 2015 So I should be able just to use the out on the Midi i/o correct? so J11->midi I0-> Quad IIC BLM connector
latigid on Posted October 29, 2015 Author Posted October 29, 2015 So I should be able just to use the out on the Midi i/o correct? so J11->midi I0-> Quad IIC BLM connectorYes, it should work from J11E. Or if you connect a MIDI IO board, you could for instance take MIDI IO4 from J2.
Phatline Posted October 30, 2015 Posted October 30, 2015 i got a message from FORMULOR:Ihre Datei enthielt Effektfilter zum abrunden der Ecken.Diese werden von unserer Maschine als Rechtecke ohne Abrundung interpretiert, da dies nur ein visueller Filter ist und nicht vektorisiert ist.Für die Produktion haben wir die abgerunden Ecken in Vektoren umgewandelt, um Ihnen ein gutes Ergebnis liefern zu können.Die Produktionsdatei finden Sie am Ende dieser Nachricht.I dont get the product up to now, so i cant proove that, i let you know... BLM_spacer_3mm_Formulor.eps
latigid on Posted October 31, 2015 Author Posted October 31, 2015 (edited) Okay, thanks for the file, let's see how yours goes and I can add it to the OP. I didn't have issues with mine (corners are properly rounded) and I think TK.s was also good? In any case, the spacer holes are a few mm larger than the buttons. Edited October 31, 2015 by latigid on
TK. Posted November 1, 2015 Posted November 1, 2015 TK.: very nice! It looks like the slider implementation is very good. I guess you kept the longer sliders in? This will be a personal preference I suppose. An idea I had was to make or buy some silicone covers to use as slider caps. This might make them a bit more ergonomic and also act as diffusers for the LEDs which can be quite bright. The long slider shafts are ok for me. LEDs are too bright (especially the white ones) with a 220 Ohm resistor, I will probably replace it by a 1k resistor. Silicone covers would be nice. I take it that there's no issues with the case? Stability (i.e. no PCB flex) is good with the extra standoffs? Are all M2 grub screws installed? Do the bottom feet work? Thanks for the reminder about the bottom feet, I forgot to install them and that's also the reason why the case slipped sometimes during the video recording. Now it's stable. Yes, I installed the M2 grub screws, PCB is stable when I push the buttonsOkay, thanks for the file, let's see how yours goes and I can add it to the OP. I didn't have issues with mine (corners are properly rounded) and I think TK.s was also good? In any case, the spacer holes are a few mm larger than the buttons.They are good, but I've only 4 spacers, a spacer for each screw would be better to avoid that the PCB is bended during mounting@Altitude: nice panels :)Best Regards, Thorsten.
latigid on Posted November 1, 2015 Author Posted November 1, 2015 The long slider shafts are ok for me. LEDs are too bright (especially the white ones) with a 220 Ohm resistor, I will probably replace it by a 1k resistor. Silicone covers would be nice.Notice I recommend 10k for the LED resistors, hopefully you can change them. For the covers, perhaps some sort of silicone block or tube could be used, I had a look at the hardware store this week but didn't find anything. Or unmelted hotmelt glue sticks? They are good, but I've only 4 spacers, a spacer for each screw would be better to avoid that the PCB is bended during mountingI don't quite understand; only two circular "washers" should be needed (right-most top and bottom viewing from the PCB front) as the remaining PCB area is covered by the spacer?
Phatline Posted November 2, 2015 Posted November 2, 2015 i got a message from FORMULOR:I dont get the product up to now, so i cant proove that, i let you know...BLM_spacer_3mm_Formulor.epsyes it works:
Altitude Posted November 7, 2015 Posted November 7, 2015 And wood is done:) I'll post the file if anyone wants it
