BLM 16x16+X build guide
53 minutes ago, Claire said:
Just a question really: why through hole diodes?
When building monome kits (the new ones, the slim, grid kid 128) I found the migration from through-hole diodes to SMT to be really very helpful on repetitive tasks (tin pad, heat pad, slide diode into pad, solder other pad: repeat). OK you trade the fiddlyness of small easy to incorrectly invert diodes but there is no bending cutting and board flipping and because of the low profile of SMT parts diodes can go on the silicone side easily enough if needed.
The idea from the start was to minimise the SMT and use commonly available parts where possible. The LEDs were different as they sit in a routed channel, but that was part of the choice for resistor networks in chip packages rather than discrete. Something like this would be a great investment:
THT are a cent each in quantity, more for SMT. MELF = mostly ends up lying on the floor, so you'd likely go for one of the SOD packages.
Looking at the design again, I think SMT would work on the rear side most of the time (disagree about the front side, you want that as flat as possible), but there are parts of the board where diodes bridge a layer. It's a complicated PCB and keeping one footprint simplifies the process. I don't think I'm prepared to redo the whole thing again because it's a lot of work and the risk would be on me not to propagate errors.
@latigid on are you going to make this board available again? I have my work cut out with a project at the moment but I'd be interested in getting back into grids at some point but monome is going in a direction that is a bit eurorack-centric for me and the max-msp/serialosc/computer side of things seems to be slipping a bit.
I can't do a big order like this without paying taxes. Especially as a foreigner in DE it's not straightforward to wade through all of the bureaucracy and set up a business. I know you've just signed up, but it seems over the last year or so a lot of "puff" has gone out of the forum. It's less desirable to go through all of that without an active community presence (I realise the chicken-egg analogy of supply and demand being mutually dependent).
I need to stick my finger in the wind so to speak and also check on my situation here. What I'd most like to see is a return to the motto of "Community Designed MIDI Devices" printed as part of the forum logo.
It would be nice to see this branch out to other applications other than the SEQ, has it been used anywhere else that you know?
@Phatline makes good use of it in his Triggermatrix.
Best regards,
Andy
Link to post
Share on other sites
  • Replies 183
  • Created
  • Last Reply
Top Posters In This Topic
Popular Posts
I've wired up the DIN and mounted the board in the case. The BLM is ready! Now, I'm just waiting on a quad IIc board to connect it to the sequencer.
Here I will document the parts list and build guide for all BLM users. Once there's a bit more knowledge a wiki page could also be written.   BOM: http://www.mouser.com/ProjectManager/P
A New BLM is Born! Thanks to Thorsten and Andy!
Posted Images
Ok all good reasons. If a new build happens I'll hopefully be on it. I do think you are being a teensy hard towards SMD diodes (but yeah I had a tray of SMD LEDs go that way...ugh). They are just as common as through-hole and just as cheap from experience, but I'm weird and find SMD 1205 and 0805 to be easier than through hole... and so many parts are now in TSSOP over PDIP -- I'm probably in a minority like that...
When I get an Eagle file I usually look for ways to convert through hole parts into SMD, it helps make things very slim profile for Skiffs and so on and I can get bigger boards into Eagle's Freemium size (I really really must get a proper licence some day).
If you ever have a waiting list for boards I'll be get on it.
Thanks for the detailed response
Edited by Claire
Link to post
  • 1 month later...
  • 10 months later...
cut that man some slack, if he says, there will be a new edition, then there will be one! :-)
(i can only imagine how much work running a bulk with a project that size really is - and there might always be other priorities like girls, football, work and babies in life! :-))
Many greets,
Peter
Link to post
  • 5 months later...
i am finishing my second BLM, and i have a problem:
horizontal Xtra row, the last four(most right) led pairs want show up (seeing with running light), also the buttons for it dont react -  what part could be the problem
i already replaced q33 and r45
-while soldering i replaced rn19, and lost some pads... which pad  is for the last 4 leds?
i also used a hot-air fanl, so maybe ic19 (next to rn19) could be faulty?
on vertical row led pair 5-8 (counted from below, over shift) only give me the left led (each led of the 4th block) - but buttons are working
where to start debuging? thx for help.
Edited by Phatline
Link to post
This current sink runs to pin 16 of RN18
You could try to bridge the current sink and pin 15 of IC18 with a 1k resistor as shown (actually to the SMD pads):
5aae3eedb7c4f_currentsink180318.thumb.PN
The extra column LEDs are also connected to the extra row. If right LEDs fail to light, is this also true for every third LED (right-hand LED) on the extra row? (Normally I would count the extra column LEDs from the top; from your meaning I am guessing this is the third set of four using this counting system.)
These LEDs are all connected to RN19, pin 10. Pin 7 of RN19 then connects to IC18 IC19, pin 5.
Best,
Andy
Edited by latigid on
Link to post
first to the horizontally:
  it turned out that the left leg (top viewof part) of q33 is somehow  grounded....
i removed r45, q33, 1n4148 and RN18, and its still groundet > i found out that RN18  had a short on the pcb between ground and the pin where you draw the connected the yellow airwire (rn18 pin 9 when i count that ics right...), i scratched the chopper away with a knife:rn18-short.thumb.jpg.acf3e8de71f37adaf95
-well that block is working now except one LED - the missing led  (the led itself is working, i removed it to go shure ), on the common side its all right but on the "T"op side i have 56Ohm to ground, while on all other LEDs have 5Mohm to ground...  it is connected to RN19, which is a 56 ohm network, so it has to be groundet somewhere on the other side of the network... the network where i lost some pads in the past, ok desolder it with hot air fan....
rn19-overheated-pads.thumb.jpg.5b151d954
ok what i see is not very good: Pin 7 is groundet, and removed from pcb (the chopper pad has moved) ok clean up and connect it directly to ic19 Pin 5,
also Pin 9 looking bad because it is loosing pcb contact... so better also remove the pad, and make a airwire..., but in order to solder it on this tiny tiny tiny thruhole connector, i have scrath a new "via" with the ground plan around it... in  order to mechanicly connect the wire
rn19-new-wire.thumb.jpg.ffacd9dd038d4d07
conclusio:RN19 i messed up by trying to desolder it leg by leg... > always desolder chips with Hot AIR FANs
conclusio: RN18 make bigger traces around Ground Plane and Signal Pathes... a single tip with the soldering iron can mechanical withen  the copper to make a ground short....
its all working now!
Link to post
This is the main thing. Well done!
Your second photo represents the problem nicely: sub-optimal registration between the soldermask and copper plane. This, along with a) white soldermask that typically scratches easily and b) a 0V plane with tight clearance to the signal pads, can lead to these annoying ground shorts. I'm sorry for the hassle. This was a few years ago now, nowadays I increase the clearance :).
One tip: you could get some enamelled copper wire for these little patch jobs. You could even salvage an old transformer and unwind the coil. To make a joint, cut the wire to size and melt through the plastic insulation to form a good joint. (see also Reichelt: FAEDELSTIFT WW)
Link to post
  • 4 weeks later...
i have made a stop motion video,
about the soldering the pcb... i have cut it to 6 minutes, so not all stuffed parts are shown, but most of part-groups
the music is drumside made with the BLM:
haveing more stop motion videos about lre2x8, core, din, mf-ng, and others... coming in future online (when having time to cut and deciding which music track under it...) (made with a lumix g85)
Edited by Phatline
Link to post
  • 2 months later...
  • 9 months later...
  • 1 year later...
11 minutes ago, xarolium said:
i would be very happy to buy a pcb for this project,any left? And what about the case?
something is brewing in the lab - we're currently working on it! :)
Many greets,
Peter
Link to post
Many greets,
Peter
By the way do you need help to design a new pcb, I m prototype designer and can provide some service to help day community ;)
Link to post
Guest
Reply to this topic...
