RGB tact switch CANCELLED
latigid on
I will soon be ordering some custom parts and I thought it might be a good opportunity to get some special switches at the same time.
TSBL6SV-BS-B8.2T10-RGB-3M.thumb.gif.2f87
This is an RGB tact switch with a common anode. The key specs are:
Brightness (RGB) 320, 300, 110 mcd, so similar to the LEDs used in the BLM.
Viewing angle: 120 degrees.
Lead spacing: 4.5*6.5mm
Cap dimensions: 7.8*7.8mm
Pricing is not fixed yet but could be around 2-2.50 USD per piece.
Please indicate any quantities that you would like. It's not a commitment to buy, it just gives me some idea during the order process.
Edited by latigid on
  • 3 weeks later...
