jbdiver Posted December 23, 2015 Posted December 23, 2015 I need to program a couple PIC16F88 chips for a new quad IIc midi module. I downloaded the mbhp_iic_midi_v1_0c.zip file containing the firmware. I'm trying to use a pickit 2 programmer to write the project.hex file to the chip. However, the programmer software reports that it cannot read the hex file. Is there a way to burn the software on these chips using pickkit?
Shuriken Posted December 24, 2015 Posted December 24, 2015 There is a problem with white spaces in the file. Try this project.hex, or remove them yourself and it should be ok.
jbdiver Posted December 30, 2015 Author Posted December 30, 2015 Thank you. Your hex file worked great.
