Random generator range
k2z3k0
hello there
short question
would it be possible to switch center of range of Random generator from 64 to 0 or 127
for example Holding SELECT key and rotating encoder of desired parameter
so then the range of parameter will define how far from that center it will go?
happy new year to all
  Kazik
Edited by k2z3k0
hi Thorsten
i have midibox seq v4
also now i realised
when my track is in CC MODE and if i press and hold Parameter Layer key C (and i have more than 4 layers mode track) in order to choose layer for edit
above each layer there is only "CC" also in Note MODE there is only "CC"
maybe could be possible to put there for example "Lay(letter of layer)" and/or "C(cc controler number)"
best regards
  Kazik
Edited by k2z3k0
Ok, I added two new items to the wish list:
Random generator: allow to select random range (e.g. SELECT button)
http://midibox.org/forums/topic/19867-random-generator-range/?do=findComment&comment=172921
Parameter Layer display: show CC#<number> for CC layers
http://midibox.org/forums/topic/19867-random-generator-range/?do=findComment&comment=172944
