idea/request led_mode=
Zam
Hi
Just an idea, not a real need (but it can be fun, and i will use it for sure)
something like a led_mode=blink for .NGC with associate parameter blink:on:100:off:300 for time in ms for each led state?
or defined time with 2 value map
or just 3 "blink" predefined mod, blink_slow, blink_mid, blink_fast
Anyway, the idea is to have a blinking led function when led is on, because a NGR script (set led and delay) is stopped a soon as another section is called
Best
Zam
Hi, I come back with this.
Nobody interested? Or I miss some NG strategy already available to perform this?
I'm just thinking out loud, but maybe it's possible to use the dimmed= with very slow PWM setting, if the frequency is not locked by the sr clock ?
Best
Zam
  • 1 year later...
  • 1 year later...
I created some metas by myself already. So aren't you able to create a meta, that switches an LED (which is part of the meta-event) on and off with a delay of x-ms? I don't see why this shouldn't work... but I never tried it by myself... you could even add the delay to the meta-message. It's very easy to set up. You just have to edit the mios32_event.c and .h. You can use an already existing meta as example.
Edited by FantomXR
Hi
At mios32_timestamp.c
does this can be used ?
//! Use this function to get the delay which has passed between a given and
//! and current timestamp.
//! Usage Example:
//! \code
//!   u32 captured_timestamp = MIOS32_TIMESTAMP_GetDelay();
//!   // ... do something ...
//!   u32 delay_in_ms = MIOS32_TIMESTAMP_GetDelay(captured_timestamp);
//!   MIOS32_MIDI_SendDebugMessage("Delay: %d mS\n", delay_in_ms);
//! \endcode
//! \return the delay between the given and the current timestamp
s32 MIOS32_TIMESTAMP_GetDelay(u32 captured_timestamp)
  // will automatically roll over:
  // e.g. 0x00000010 - 0xfffffff0 = 0x00000020
  return timestamp - captured_timestamp;
