Second Quad_IIc_MIDI Module
Karg
You need to get the PIC16F88 for the 2nd quad IIC burned with this firmware :
http://midibox.org/forums/applications/core/interface/file/attachment.php?id=11978
And you will have to change some line on your midibox firmware
mios32_config.h
#define MIOS32_USB_MIDI_NUM_PORTS 8
and you connect both boards in series, like this :
large.DSCN3750.jpg.caf67356eac363decf536
Have fun !
Edited by Lamouette
@Lamouette:
Thanks a lot. worked well. Actually it did not, but it was exactly what I needed - a hint in which file the IIC ports are configured (and the hacked PIC16 Firmware of course was very valuable as well).
For completion: the line to change in mios32_config.h is
#define MIOS32_IIC_MIDI_NUM 8
Besides solving my problem, I now also have the mios toolchain installed and can try a couple of different things! This is what I love about DIY!
