TOKEN_one Posted November 5, 2016 Report Share Posted November 5, 2016 Last sich MTC und Status auf OLED-Display darstellen anstatt mit 7 segment led. Quote Link to comment Share on other sites More sharing options...
TK. Posted November 5, 2016 Report Share Posted November 5, 2016 Hat wohl noch gefehlt - hier eine neue version: -> http://www.ucapps.de/mios32/midibox_ng_v1_036_pre2.zip Die digits lassen sich mit %L darstellen Hier ein Konfigurationsbeispiel - die bereits vorhandenen EVENT_LED_MATRIX konfigurationen muessen um fwd_to_lcd, lcd_pos und label erweitert werden: # Following example shows how LC digits could be displayed on a LCD with the events above # notes: # - replace the EVENT_LED_MATRIX configurations above by the new ones with lcd definitions # - change lcd positions by locations which are not used by other text messages yet! # # EVENT_LED_MATRIX id=33 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 64 syxdump_pos=10:0 fwd_to_lcd=1 lcd_pos=1:14:1 label="%L" # EVENT_LED_MATRIX id=34 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 65 syxdump_pos=10:1 fwd_to_lcd=1 lcd_pos=1:13:1 label="%L" # EVENT_LED_MATRIX id=17 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 66 syxdump_pos=10:2 fwd_to_lcd=1 lcd_pos=1:11:1 label=".%L" # EVENT_LED_MATRIX id=18 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 67 syxdump_pos=10:3 fwd_to_lcd=1 lcd_pos=1:10:1 label="%L" # EVENT_LED_MATRIX id=19 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 68 syxdump_pos=10:4 fwd_to_lcd=1 lcd_pos=1:8:1 label=":%L" # EVENT_LED_MATRIX id=20 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 69 syxdump_pos=10:5 fwd_to_lcd=1 lcd_pos=1:7:1 label="%L" # EVENT_LED_MATRIX id=21 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 70 syxdump_pos=10:6 fwd_to_lcd=1 lcd_pos=1:5:1 label=":%L" # EVENT_LED_MATRIX id=22 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 71 syxdump_pos=10:7 fwd_to_lcd=1 lcd_pos=1:4:1 label="%L" # EVENT_LED_MATRIX id=23 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 72 syxdump_pos=10:8 fwd_to_lcd=1 lcd_pos=1:2:1 label=":%L" # EVENT_LED_MATRIX id=24 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 73 syxdump_pos=10:9 fwd_to_lcd=1 lcd_pos=1:1:1 label="%L" # # # status digits # EVENT_LED_MATRIX id=39 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 75 syxdump_pos=11:1 fwd_to_lcd=1 lcd_pos=1:2:2 label="%L" # EVENT_LED_MATRIX id=40 led_matrix_pattern=LcDigit type=CC chn= 1 cc= 74 syxdump_pos=11:0 fwd_to_lcd=1 lcd_pos=1:1:2 label="%L" Mit lcd_pos legst Du das display und die X/Y Koordinaten fest, und mit %L wird ein Logic Digit ausgegeben. Gruss, Thorsten. Quote Link to comment Share on other sites More sharing options...
TOKEN_one Posted November 5, 2016 Author Report Share Posted November 5, 2016 Die vor Compilerte geht super Wenn ich bei mir jetzt Compiler nach dem Aktualisiern vom SVN kommt die Meldung. CD: F:\mios32\apps\controllers\midibox_ng_v1\ Current directory: F:\mios32\apps\controllers\midibox_ng_v1 make Process started >>> rm -f project.hex f:/mios32_toolchain/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: project_build/project.elf section `.bss_ahb' will not fit in region `RAMAHB' f:/mios32_toolchain/bin/../lib/gcc/arm-none-eabi/4.7.4/../../../../arm-none-eabi/bin/ld.exe: region `RAMAHB' overflowed by 10176 bytes collect2.exe: error: ld returned 1 exit status make: *** [project_build/project.elf] Error 1 <<< Process finished. (Exit code 2) ================ READY ================ Hilfeeee Quote Link to comment Share on other sites More sharing options...
TK. Posted November 5, 2016 Report Share Posted November 5, 2016 Ich habe in den letzten Tagen auf eine neue FreeRTOS Version umgestellt, dabei habe ich vergessen ein wichtiges Feature fuer den LPC17 zu aktivieren... Update nochmal das repository, es sollte nun funktionieren. Gruss, Thorsten. Quote Link to comment Share on other sites More sharing options...
TOKEN_one Posted November 5, 2016 Author Report Share Posted November 5, 2016 (edited) Super Funzt Danke Edited November 5, 2016 by TOKEN_one Quote Link to comment Share on other sites More sharing options...
