Set variables question
Duggle
Is it supported to have the channel of a CC (or Polypressure) event represented by a variable.
The application is to be able to change the channel destination of an encoder CC event to a different voice in a synth editor.
It is possible to adjust the same parameter with a sysex short message where the voice is addressed by a part# field in the sysex string but it will mean a lot of work (re)writing a very large configuration.
What about port? What would be the way of selecting a different port for messages. The application is to have another same kind of synth on an alternative port (e.g Virus B on Uart1 and a Virus C on Uart2) and switch the editor between them.
Link to comment
Share on other sites
Such features are currently not provided.
The big question: is the usage of variables really the right approach? What if you want to control both synths from a single control surface?
Or would it be better to provide new .NGR commands which allow to change the channel and port assignment for each event?
Best Regards, Thorsten,
Link to comment
Guest
Reply to this topic...
