goyousalukis Posted January 22, 2018 Report Share Posted January 22, 2018 Hey Guys, a few quick questions. I went overboard, and ordered the MBSid control PCB from Modular Addicts, and all the associated components from Mouser/Amazon. I am converting my old MBSid to a V2. I want to use my existing MB Core, SID, and DOUT/DIN, etc. I only have 2 Sids/cores. The Modular Addict webpage only shows a front view of the PCB. I assume I can connect my components to the panel no problem right? Is there a layout/schematic of the pcb somewhere? I didn't see it. If I get this up and running, I may go nuts down the road, get the mainboard PCB and make an 8 SID version. Finally, is there a DXF for the panel somewhere? I have a CNC and a Laser engraver, so I plan to cut it myself. Thanks, Quote Link to comment Share on other sites More sharing options...
Smithy Posted January 25, 2018 Report Share Posted January 25, 2018 The files you need are in the mb-6582 Wiki. http://www.midibox.org/dokuwiki/doku.php?id=wilba_mb_6582 1 Quote Link to comment Share on other sites More sharing options...
