PCBs for sale
latigid on
Doing a bit of spring cleaning, maybe these might be of interest. Prices in euro plus shipping
  • 20180203_114614.thumb.jpg.c7ea79a739fb03
  • Pads WS2812 LEDs and Sparkfun silcone buttons/matrix
  • Availability: 10
  • Price: 8
  • 20180203_114653.thumb.jpg.40a2bdffee073b
  • Encs  WS2812 LEDs and illuminated encoders
  • Availability: 10
  • Price: 10
  • encoders: 1.5 each
  • 20180203_114750.thumb.jpg.10576bd87957e9
  • ELO WS2812 LEDs, illuminated encoders, optional touch sensors, OLED displays mounted at 45 degrees
  • Availability: 13
  • Price: 20 (it's a four-layer board...)
  • 0.96" white OLED: 5 each
  • 20180203_114721.thumb.jpg.9fb32249bd4e8d
  • CS1 button matrix, encoders (some illuminated), LCD/OLED mounting
  • Availability: 8
  • Price: 12
  • 20180203_114557.thumb.jpg.05e86764f4d612
  • DIN6DOUT4 SRIO, works well with Pads, Encs and CS1. Level shifter for 16 outputs (e.g. higher-voltage gates etc.)
  • Availability:  9
  • Price: 6
  • 20180203_114812.jpg.6873cec5238c5d6a6af0
  • MiniCore PIC, designed for BLM but could be useful elsewhere
  • Availability: 3
  • Price: 5
  • 20180203_114457.thumb.jpg.f311723183580e
  • Disp. driver buffers and CS lines for OLED displays (32 per PCB). Works, but J15 connector is mirrored...
  • Availability: 8
  • Price: 5 or 2 with any other purchase
  • 20180203_114900.thumb.jpg.c7bf77ebe92574
  • SCS OLED many configurations possible (1-4 OLEDs, encoder and/or buttons)
  • Availability: 7
  • Price: 6
  • populated with 4xOLED: 25 (1 available). Looks a bit dusty, but screen protection still on :sunglasses:
  • 20180203_114956.jpg.360914f5fc5d12633afc
  • AOUT4 MAX525-based AOUT, four channels
  • Availability: 6
  • Price: 5
  • 20180203_115018.thumb.jpg.fdb305fc3b705c
  • AIN4 protection/scaling circuit interfacing to a 3V MCU, four channels
  • Availability: 8
  • Price: 5
Edited by latigid on
updated
  • 3 weeks later...
0204 is just the "wire link" resistor package. Notice one of the pads is connected to the encoder body, so bridging the TS parts as drawn as a "resistor missing a side" with wire will connect the metal surface to the DIN chain. Then something like a metal washer or custom CNC part can be connected to the encoder body using the thread/nut/washer.
It was done like this so that the TS functions can be separate from the encoders if needed, and also that the metal surface can be "processed."
  • 3 weeks later...
Just follow the normal LCD setup by defining the desired number of displays through the bootloader app. I think the first 8 are still selected by J15, but I'm sure you could configure 64 lines using the Disp Driver CS if wanted.
It may be useful to power the driver at +5V if the OLEDs are locally regulated.
  • Like 1
ok cs0-7 directly from core, the others then from display-driver - i think i will plug Display 0-7 then in J15B. and the  display driver with that mirrored cable on J15A then... (may 3.3 5V problems accour? see my last sentence below)
hmm what about J9 - for what is that? should that be a output or a input? i dont measure voltage there... do i have to connect to core? anwhere?
do you have wired already displays with that pcb? , a photo additional to wiki - would be helpful: http://wiki.midibox.org/doku.php?id=display_driver
what i see, i have to paralell wire 8 displays per 2x5 socket, and single wire the cs coming from the 2x5 socket,
the ground i can take from the 2x5 socket,
the +Potential  (in your shematic its 5V) i dont found... maybe that J9? on the 2x5 i dont found that 5vdc+. ....
by the way in this document: http://ucapps.de/mbhp/mbhp_lcd_ssd1306_single_mios32.pdf the display is connected via 3.3V, in your diagram it is on +5V
Sorry for missing this; J9 is the power supply if you would like to supply it through the J1-8 headers. It's separate from the 3v3 supply.
Here is the correct wiring (a bit messy)
fetch.php?w=600&tok=57ca86&media=dispdri
Yes. The SPI data/clock/#DC can be shared between a few OLEDs (e.g. ELO or SCS-OLED) with a separate CS to each display.
Or you can power the displays directly from your PSU. Depends on the current etc.
I think I did it this way as Core J10B is wired to 3v3 (3v0 on a Disco board). Generally the logic levels shouldn't be mixed. It's just a matter of how the display expects its data.
  • Like 1
Just a quick note: The OLEDs I received are able to run at 5V instead of 3.3V. They are also brighter at 5V. So you might not need a 3.3V reg. If you use an external 5V power supply for your cores, you are able to power them directly through this.
I'm pretty sure this is valid for other OLEDs too. I order mine at aliexpress for about $3 / pc.
