Aout_NG Not working on midibox seqv4
flyweight
Hi Guys,
I am finaly near the end of my build of a seq4. Only need to have the Aout_ng and possible the D-out working.
The D-out I will try to build on a breadboard for some extra gates and clocks.
Realy looking forward for the awesomeness of controlling a modular with the midibox.
Thanks again TK for bringing the AWESOME project to the public.
Would you have any idea what can be the issue here with my aout_ng? Does anything below indicate wrong wiring?
MBSEQ_GC.V4: "CV_AOUT_Type" and set it to 3 for AOUT_NG
And on the CV Configuration Page the aout_ng is set.
Core STM32F4 AOUT_NG on j19 Connected like
J1:1 -> J19:Vs
J1:2 -> J19:Vd
J1:3 -> J19:RC1
J1:4 -> J19:SO
J1:5 -> J19:SC
At least I hope.
No led is enabled on the Aout after booting the midibox and the DAC is not getting warm.
I have only J1-j19 connected so no 12-/+ V on J3
On pin 20 on the TL5630 I got 4.5V on pin 11 as well
-Aout not set in the config
4.5v on pin5, 20, 23 and 11 of the dac
-Aout set in the config
4.5v on pin2, 5, 20, 23, 11 of the dac
[6016.659] Setting AOUT:CS pin to ca. 5V - please measure now!
4.5v on pin2, 3, 4, 5 of the dac
[6016.659] Setting AOUT:CI pin to ca. 5V - please measure now!
[6476.996] Setting AOUT:SC pin to ca. 5V - please measure now!
4.5v on pin2,3,4,5 of the dac
Does anybody has a hint what I should check?
Thanks in advance,
Cheers
Tim
Hi Slo,
Thanks for the help.
From the AOUT documentation: http://www.midibox.org/dokuwiki/aout_ng
"You can leave out the TL074s for a first test. Then connect J1 to the core. Power up your Midibox. If the LED doesn't light up, IMMEDIATELY switch off power and re-check all connections and soldering."
"If the LED is on, you can now connect analog power (+/- 12V) to J3."
So I expected the led to power up, but it doesn't
I ran the tests and get:
Pin 1 VS, 2, VD
CS test J1 pin 3 high
SI test J1 pin 4 high
SC test J1 pin 5 high
So the wiring seems good.
Cheers
Tim
Ohhh no I removed the DAC yesterday but looking back to my notes I actually had 5v on pin 5 on the dac (/PRE ).
I just learned that the flatside of the led symbol means Cathode, which is the -
So there is a high change that I have the LED connected wrongly. I mean 5v on the /PRE input should light up the LED right?
Would wrongly placing the led mean a non working aout?
If the led is wrong I will re solder the old DAC first otherwise I will bet on  a new one.
Quote
No, not if you installed the LED backwards. The LED only indicates power is available at the PCB, the Aout_NG would work without it. Remove the LED, test it with a 9v battery and resistor, if it lights install it the right way and if you didn't damage the DAC on removal, re-install it.
  • Like 1
I'd very interested to hear your report and I really hope it works for you. I could not get my Aout_NG working and gave up after many tries, 1 or 2 other people have experienced the same thing after doing everything right, so your input will be welcome.
Ok I got a new DAC.
the led is lightup.
J1 Pin 1, GND
J1 Pin 2, + 4.5V
[24708.300] Setting AOUT:CS pin to ca. 5V - please measure now!
J1 pin3   4.5v
[24683.868] Setting AOUT:CS pin to ca. 0V - please measure now!
J1 pin 3   0v
[24742.891] Setting AOUT:SI pin to ca. 5V - please measure now!
J1 pin 4   4.5v
[24755.116] Setting AOUT:SI pin to ca. 0V - please measure now!
J1 pin 4   0v
[24775.452] Setting AOUT:SC pin to ca. 5V - please measure now!
J1 pin 5   4.5v
[24790.716] Setting AOUT:SC pin to ca. 0V - please measure now!
J1 pin 5   0v
The cables seem good.
A new dac is soldered which I carefully inspected.
Now +-12v is connected to j3.
On the TL074s +-12v is measured that is pin 4 +12v.
In bipolar mode I get about -2.6v on all 8 channels, caliaout 1 max does nothing, neither does changing the calibration voltage on the midibox itself.
I am trying to find very hard if I soldered something wrong but that it doesn't seem like that.
Anybody any tip what I should do?
Ah I seem to have sucses.  When I disabled th aout_ng in the config, saved it and turned the midibox off. Then turned it on again, selected - aout-ng and tweaking the calibration voltages gives me output!!!! ITS ALIVE!!!
It's to bad that most likely the first dac was fine as well and this does look like a bug. (not sure)
I will continue the tests another day.
Cheers,
F*cking happy Tim
Great that this helped at your side! :)
But for the records: currently I'm not able to reproduce this issue.
The test procedure:
  • turn on MIDIbox with unconfigured AOUT module
  • in CV page selected AOUT_NG module
  • exit CV page (so that this setting will be stored)
  • power-cycle MBSEQ
  • -> AOUT_NG properly configured and working
  • can be repeated with multiple power-cycles: AOUT_NG properly configured and working
Hi T,
Only 1 thing i did not mention is that I applied a bit off pressure on the tl074's so most likely i did something wrong. Maybe the contact wasn't ok before. Althought +-12v was there.
I will try if i can reproduce it on my side. But if i do than highly likely I did something wrong here.
Cheers
Tim
