Starting up the dual manual organ
macsaif
14 hours ago, macsaif said:
What kind of SD card do you recommend? Are there any limitations or recommendations: speed,  capacity, manufacturer?
No, anything should work. NGC-files are very small. So 12MB would be sufficient, but you won't be able to find a SD-card like this. Just take what you have or what you can get.
I have sterted up th NG. The velocity is not as sensitive as the direct KB... However I can achieve much more better velocity response by using the velocity map function. Now I have to implment the control of MiB, Transpose, keyboard split and Midi channel mapping (controlled by 16 hw inputs of STM32) and I can continue with the second board controlling the patches, banks, cc parameters.
At the moment I have checked the BreakIsMake function controlled by DIO. It works.
I think I can do the transpose (Octave -2, -1, 0, +1, +2) function based on the example however I need some help. Is there any function where I can handle several transpose values based on the combination of 3 DIO bits?
000 – No transpose
001 – Octave +1
010 – Octave +2
101 – Octave -1
110 – Octave -2
Or
000 – No transpose
100 – Octave +1
101 – Octave +2
110 – Octave -1
111 – Octave -2
Where I need to define it...in .NGC or in .NGR file?
The second question is regarding the assigning the Midi CHannels to Keyboards and Splitting. I have seen an example for Splitting, I think it is possible to make  more Event_Keyboards listening the same HW and activating them based on the DIO bits. I have to make the following combinations
1. KB1 – CH1, Kb2 – CH4 ,     DIO- 000
2. KB1 – CH1, KB2 – CH2,    DIO-100
3. KB1 – CH1, KB2 – CH1 + CH4,   DIO-010
4. KB1 – CH1, KB2 – split at C2, lower part – CH3, Upper part – CH2,   DIO 101
5. KB1 – CH4, KB2 – split at C2, lower part – CH3, Upper part – CH1,  DIO- 111
6. KB1 – CH4, Kb2 – CH1, DIO- 011
Is that possible to realize in Midibox NG?
I am trying the transpose function switched by DIO register, it works however negative values are not supported. Here is my ngr file
if ^section == 1
set_kb_transpose KB:2 12
endif
if ^section == 2
set_kb_transpose KB:2 -12
endif
if ^section == 3
set_kb_transpose KB:2 0
endif
If I change the - 12 value for example to 24, it works however - values are not supported and it gives an error message. How can I make negative transposing?
Thank you in advance
Edited by macsaif
The transpose problem is solved, thanks to T.K.: no negative values are allowed I had to use valuse between 128 and 255.
Next question:
I am trying to apply the Midi channel changing function. My solution is to make 7 different .NGC/.NGR files. Each .NGC file will have different setting of KB1/2 to Midi channel 1-4 mapping. In NGR file I will call the different .NGC files (load xxx). I have tried  it however it seems it does not work. My questions:
1. If I call a new NGC file does it substitute the running Default NGHC file or the Default stays running?
2. Can I use the same event id numbers in all NGC files or I have to use different id numbers in each NGC file?
3. Is it a good solution or there is an easier way to do that function?
Thank you
Frank
Hello
You can change config with LOAD command at .NGR
You should be able to select a keyboard event definition with conditional.
EVENT_KB hw_id=1 id=11  type=NoteOn chn=1 key=any use_key_number=1 range=0:127  if_equal=button:1:1
EVENT_KB hw_id=1 id=12  type=NoteOn chn=2 key=any use_key_number=1 range=0:127  if_equal=button:1:2
EVENT_KB hw_id=1 id=13  type=NoteOn chn=3 key=any use_key_number=1 range=0:127  if_equal=button:1:3
map1 1 2 3
EVENT_BUTTON hw_id=1 id=1 value=1 range=map1 button_mode=toggle
Banking or radiogroup should work too, it depend how you want to select the channel
Best
Zam
Or you maybe could do it with a NGR script. I didn't test it, but this might work.
Set up a button in your NGC like this:
EVENT_BUTTON id=1 type=meta meta=runsection:1 range=0:127
EVENT_KB hw_id=1 id=1  type=NoteOn chn=1 key=any use_key_number=1 range=0:127
EVENT_KB hw_id=1 id=2  type=NoteOn chn=2 key=any use_key_number=1 range=0:127
In NGR you add this:
if ^section == 1
 if id(Button):1 127
  set_active (id)KB:1 0
  set_active (id)KB:2 1
 endif
 if id(Button):1 0
  set_active (id)KB:1 1
  set_active (id)KB:2 0
 endif
endif
And you have to add also this. Without this both KBs would be active on startup:
if ^section == 0
endif
Edited by FantomXR
I want to change the channell based on the combination of 3 inputs. The combinations are:
if ^section == 1
 if id(Button):1 127
 endif
 if id(Button):1 0
 endif
endif
if ^section == 0
endif
Can I make 8 software keyboards and switching them based on the combination of 3 input bits?
KB:1 - hardware kb1 to ch1
KB:2 - hardware kb1 to ch4
KB:3 - hardware kb2 to ch1
KB:4 - hardware kb2 to ch2
KB:5 - hardware kb2 to ch4
KB:6 - hardware kb2 lower part up to C2 to ch3
KB:7 - hardware kb2  upper part from C2 to ch1
KB:8 - hardware kb2  upper part from C2 to ch2
What happens when I am deactivating a KB and I have some keys pressed? I want to avoid some hanging notes when switching between configuration!
Just now, macsaif said:
I am using the 16 digital inputs mapped to shift register 5 and 6. The transpose and BiM function is working.
DIO 000, 001, 010 ...111 represents 3 bits from the 16 inputs.
Is that 3 bits definition at .NGC ??
DIO define emulated SR, you have direct access with the hooked button and corresponding hw_id
I guess your first DIO button is hw_id=33 and last is hw_id=48 (if SR 5 and 6)
But if I get it  right you want to use 3 button to define 8 keyboard states ?
000 is all button off
001 is button n°3 on
011 is button 2 and 3 on
etc...
111 is all button on
can you confirm that is the logic you want to implement ?
Best
Zam
Yes, this is the logic and it works, the problem is somewhere else. I have tried the simple layer and split function and there are the following problems:
Layer: I am assigning the KB1 and KB2 to HW ID 1 , KB1 to CH1 and KB2 to CH4
EVENT_KB id=1 hw_id=1 type=NoteOn chn=1 key=any use_key_number=1 range=0:127  kb_velocity_map=map1  kb_transpose=0 ports=1000110000000000
EVENT_KB id=2 hw_id=1 type=NoteOn chn=4 key=any use_key_number=1 range=0:127  kb_velocity_map=map1  kb_transpose=0 ports=1000110000000000
1. At the first key press the midi event is sent to CH1 and CH4,then to other key presses are sending only to CH4 however each keypress is sending 2 on and 2 off signals to CH4
2. The other problem is that the 2 signals have different velocity value, it seems that the second key press event is sending higher velocity value,
Split mode:
EVENT_KB id=6 hw_id=2 type=NoteOn chn=3 key=any use_key_number=1 range=0:67  kb_velocity_map=map1  kb_transpose=0 ports=1000110000000000
EVENT_KB id=8 hw_id=2 type=NoteOn chn=2 key=any use_key_number=1 range=68:127  kb_velocity_map=map1  kb_transpose=0 ports=1000110000000000
It is sending only events to CH3 and not only until splitpoint however in whole range.
KB id 1 and 2 are assigned to the uppermanual and KB id 3-8 are assigned to the lower manual(73 key)
The layer:
[13608.608] 90 45 14   Chn# 1  Note On  A-3  Vel:20
[13608.608] 93 45 3c   Chn# 4  Note On  A-3  Vel:60
[13608.681] 93 45 00   Chn# 4  Note Off A-3 (optimized)
[13613.072] 93 45 14   Chn# 4  Note On  A-3  Vel:20
[13613.072] 93 45 3c   Chn# 4  Note On  A-3  Vel:60
[13613.158] 93 45 00   Chn# 4  Note Off A-3 (optimized)
The split:
[13895.421] 92 28 5b   Chn# 3  Note On  E-1  Vel:91
[13895.548] 92 28 00   Chn# 3  Note Off E-1 (optimized)
[13896.752] 92 56 6e   Chn# 3  Note On  D-5  Vel:110
[13896.881] 92 56 00   Chn# 3  Note Off D-5 (optimized)
The split point is 47(in earlier e-mail it was 67 however now it is changed to 47) C2youcansee that there is only signal to CHN3
Hello,
here is the complete .NGC file for layer configuration:
RESET_HW
SRIO num_sr=4
KEYBOARD n=1   rows=8  dout_sr1=1  dout_sr2=2  din_sr1=1  din_sr2=2 \
               din_inverted=0  break_inverted=0  din_key_offset=32 \
               scan_velocity=1  scan_optimized=1  make_debounced=1  break_is_make=0  note_offset=36 \
               delay_fastest=0  delay_fastest_black_keys=0  delay_slowest=100
KEYBOARD n=2   rows=12  dout_sr1=3  dout_sr2=4  din_sr1=3  din_sr2=4 \
               din_inverted=1  break_inverted=0  din_key_offset=32 \
               scan_velocity=1  scan_optimized=1  make_debounced=1  break_is_make=0  note_offset=28 \
               delay_fastest=1  delay_fastest_black_keys=0  delay_slowest=140
MAP1/BYTEI  0:0  1:20 20:60 60:90 90:110 118:127
