maximum performance - strip down mios32
Phatline
hey,
i have a very time sensitive case, where i have to scan a GPIO (DIN) Pin (J5) for ON/OFF states (audio>schmitt-trigger>J5)
>>> Clock 2 Audio 2 Clock:
i switched off, what i found, and deleted as many tasks i know... > see code attachment (mios config and app.c)
what task is best for scaning such GPIO? or can i change priority with switch somehwere --- i have put it into "void APP_MIDI_Tick" up to now... when a new pulse comes in a midi-clock-send signal goes out also...
the Signal-Pulses on GPIO are 2ms -on-pulses -like shown in this picture
5b317f81213bb_6ms-latency---2mspulse.thu
the first and 3rd track are recordet @once where 1st track is audio track,and 3rd track is midi-clock-click, the 2nd track is the overdubbed audio-track driven by the clock of 3rd track --- i have 6ms delay... of course there is also some delay in sound generation and other ways.but there is also quite a bit delay in the c-code...
#include <mios32.h>
u8 clock_trigger = 0;
u8 clock_counter = 0;
u8 audio_pulse_durate = 0;
u8 Start_Flag = 1;
u8 Mode = 0; //0: Sense Midi Clock, 1: Sense Audio Pulses
u8 blink = 0;
u8 count = 0;
u32 count_off = 0;
u8 loose_clock = 0;
u8 count_flag = 0;
u8 Start_sense = 0;
void APP_Init(void){ // set GPIO
// Set GPIO
  // J5A0 >> DIN  - Pull-DOWN - Audio Input > Sense    Pulses     from Schmitt Trigger
    MIOS32_BOARD_J5_PinInit(0, MIOS32_BOARD_PIN_MODE_INPUT_PD); // Push Down //connect to 5V
  // J5A1 >> DOUT - Push-Pull - Audio Out   > Generate Pulses     for Record
    MIOS32_BOARD_J5_PinInit(1, MIOS32_BOARD_PIN_MODE_OUTPUT_PP);
    MIOS32_BOARD_J5_PinSet (1, 0); // Turn off PIN > init
  // J5A2 >> DIN  > Pull-UP   - Record Button
    MIOS32_BOARD_J5_PinInit(2, MIOS32_BOARD_PIN_MODE_INPUT_PU); // Pull-UP //connect to ground
  // J5A3 >> DOUT > Push-Pull - LED
    MIOS32_BOARD_J5_PinInit(3, MIOS32_BOARD_PIN_MODE_OUTPUT_PP);
    MIOS32_BOARD_J5_PinSet (3, 1); // Turn ON PIN > init
void APP_Background(void){ // Switch + LED + MODE (play rec) set + Auto-Stop
    //Scan Mode-Switch //deep88 - Switch Version
    u8 temp = Mode;
    Mode = MIOS32_BOARD_J5_PinGet(2);
    if (temp != Mode) { Start_Flag = 1; audio_pulse_durate = 0;}
    //Mode-LED-States (to indicate Mode-Push-Button
    if (count <=  0 ) { blink = 0; }
    if (count >  12)  { blink = 1; }
    if (count >  24)  { blink = 0; count =0 ;}
    if      (Mode == 1) { MIOS32_BOARD_J5_PinSet(3, 1);}     //Turn OFF PIN   -   sensing audio pulses  dumpout midiclock
    else if (Mode == 0 && loose_clock == 1) { MIOS32_BOARD_J5_PinSet(3, 0); }     //Turn ON  PIN  - ready for sensing midiclock - ready for dumpout audio
    else if (Mode == 0 && loose_clock == 0) { MIOS32_BOARD_J5_PinSet(3, blink); } //Blink    PIN  -   sensing midiclock     dumpout audio
    if(Mode == 1) { // sensing pulse mode (send out Clock-Mode)
        // MidiClock Auto-Stop
        if (count_flag == 1) {
            count_off++;
            if(count_off > 200000) {
                count_flag = 0;
                loose_clock = 1;
                count_off = 0; //turn off blink light after loosing Midi-Connection
                 audio_pulse_durate = 0; // Pulse stop duration
                 Start_Flag = 1;
                MIOS32_MIDI_SendStop(32);     //send Stop-Sig - Port-A
                //MIOS32_MIDI_SendDebugMessage("auto-stop");  // DEBUG
void APP_Tick(void){ // Timer for Pulse-Output Duration
    if(  clock_trigger == 1 && clock_counter <= 1) {clock_counter++;}
    else{clock_trigger =  0;
         MIOS32_BOARD_J5_PinSet(1, 0);
void APP_MIDI_Tick(void){       // sensing Audio-Pulses & Dumpout Midiclockdata
    if(Mode == 1) { // Scan Mode-Switch
        // First time we get a Pulse, we send out a CLOCK-START-Signal
        if((MIOS32_BOARD_J5_PinGet(0) == 0) && (audio_pulse_durate == 0) && (Start_Flag == 1) ) { // Pulse = HI,  Pulse start duration
            MIOS32_MIDI_SendStart(32);     //send Start-Sig - Port-A
            Start_Flag = 0;
            //MIOS32_MIDI_SendDebugMessage("start");  // DEBUG
        // All other Pulses, are just Clocks, without Startsignals
        if((MIOS32_BOARD_J5_PinGet(0) == 0) && (audio_pulse_durate == 0) && (Start_Flag == 0) ) {//Pulse = HI,  Pulse start duration
            MIOS32_MIDI_SendClock(32);     //send MidiClock - Port-A
            audio_pulse_durate = 1; // Pulse starte duration
            //MIOS32_MIDI_SendDebugMessage("clock-durate-pulse");  // DEBUG
        // Ensure to kill the PULSE DURATION FLAG, after the Pulse is gone....
         if((MIOS32_BOARD_J5_PinGet(0) == 1) && (audio_pulse_durate == 1) ) { //Pulse = LO, Pulse still in duration
            count_off  = 0; // reset Midi-Stop-Signal counter >>> for Autostop
            count_flag = 1; // begin to count for Autostop
            //MIOS32_MIDI_SendDebugMessage("pulse-off");  // DEBUG
void APP_MIDI_NotifyPackage(mios32_midi_port_t port, mios32_midi_package_t midi_package){ //sense Midi Messages
        if(Mode == 0  &&  port==32) {
                // SEQ Stop Signal
                if(midi_package.evnt0 == 252) { Start_Flag = 1; loose_clock = 1; Start_sense = 0; } // when sequencer is stopped: generate midi clock & transport
                // SEQ Start Signal
                if(midi_package.evnt0 == 250  || midi_package.evnt0 == 251) { Start_sense = 1; }// start to react on midiclock
                // SEQ Clock
                if(midi_package.evnt0 == 248  &&  Start_sense == 1) {//248CLK,250Strt,251Cont,252Stp
                clock_trigger = 1;
                clock_counter = 0; //initate Clock HI-State Timer
                MIOS32_BOARD_J5_PinSet(1, 1); //activate GPIO-Pin J5A Pin 2
                Start_Flag = 1; //reset flag in order to send out a start signal when next AUDIO-PULSE COMES IN
                loose_clock = 0;
                count++;
thx for perfomance help
project.zip
