I'll attempt to explain an issue i'm having. My apologies because it's difficult to explain.
This is what i've got going on.
Track A is being step-triggered & restarted by Track B, sending/listening to T&A Bus 1. wonderful.
Track B has note and scale parameter layers which is nicely quantising the chaos.
With the duplicate FX i'm sending Track A out of an output port and back to an available in port.
T&A Bus 2 listening on this Port & Channel. My goal is to step-trigger or restart Track C via T&A Bus 2
which works, I have Bass Drum on each step on Track C being step-triggered by T&A Bus 2.
The problem is that Track A is now being restarted by both T&A busses!
So to reiterate, I have T&A Bus 1 effectively feeding T&A Bus 2 but T&A Bus 2 is restarting or step-triggering T&A Bus 1.
THANK YOU for trying to read that.
I think it's a bug.
V4+.095
could you please zip your session directory and attach it to this thread?
Maybe next week I will have some time to look into this.
