midiphy Eurorack Expander Modules
latigid on
Hello, Peter made an awesome video (4k quality!) demonstrating the assembly of the following modules
  • Euroceiver (line driver receiver in the rack), power distribution
  • A1 Expander (AOUT based on MAX5500)
  • D1 Expander (DOUTX1 for gates plus protection)
  • D2/D3 Expanders (likewise for clocks and triggers)
Feel free to use this thread for any discussion or troubleshooting. Have fun building your modules!
Edited by latigid on
  • Like 1
Thanks a lot Andy and Peter for this great work! :cheers:
Based on this video tutorial I built up my modules yesterday, all are working fine, almost no troubleshooting was required. :)
midiphy_modules.thumb.jpg.972e7328aec6d8
Now I need a case (I ordered a 4ms Pod40X in the hope that the modules will fit into this case without special measures)
Hi Niels,
These pins are intentionally bridged; see also http://ucapps.de/mbhp/mbhp_aout.pdf (amplifier circuits now a bit different and available on the transmute8 page). The next run of PCBs will indicate this a bit clearer. On the plus side, no need to unbridge these if there's too much solder!
Have fun building!
Best,
Andy
Hi, another question. I am also busy with the matched resistors and looking at peters video he uses auto range on his multimeter to get 2 decimals. Whatever i try with my fluke 87iii i always get 1 decimal. How are you getting 2 decimals when measuring the resistors?  I Guess it should work with a fluke right? Maybe not the right question for this board but since you are far better with electronics then me maybe you can help me. Cheers niels
Edited by enveevee
25 minutes ago, latigid on said:
Try to hold the yellow backlight button down for a second or so. At least this is how it works for my 87V meter.
Thanks man! works with the 87iii as well . Still trying to get an accurate reading every time because when I try several times I still get some difference of 0.01
I finished building the boards and like to test them out. I order a eurorack case and psu but i did not receive them yet.
Is it possible to power all the boards with the usb power. I tried it but didn't get any Lights on the other boards. Peters video and other screens only show eurorack power so i am in doubt.
Cheers Niels
Just now, latigid on said:
Hi Niels, you would need some sort of +/-12V power supply for the modules. Do you have any old 12V wall warts or other PSUs around? You might be able to rig up something.
Best,
Andy
Hi Andy, nice to know, i will make something in the meantime . What exactly is the use of the usb power on the first board?
The SRIO (J8/9) and J19 SPI require some sort of +5V, the source of which is selected by J5 (or SJ5). So the USB (power only) can be one of those sources, otherwise it can be regulated down from the Eurorack +12V or passed through the DB-25 cable, though I don't recommend the latter as the wires are quite thin and there will probably be a voltage drop.
  • Like 1
10 hours ago, lukas412 said:
Has anyone tested out the tracking on these yet? Are they better/worse than previous version of mbcv modules?
@lukas412 recently TK. came over for a visit, for a long walk and also to grab his new set of these modules! :) We performed a tracking test in conjunction with a purely digital oscillator on a MIDI controlled synth and could not really hear any problem at all over many octaves. That is, if you perform good calibration, which is explained in the video tutorial in chapter 64, here: https://www.youtube.com/watch?v=dD8VeSuTKWI&t=5561s
Have fun and many greets!
Peter
I installed all the modules and like to calibrate but when i power on the a1cv board all leds are all lighted red and when meassuring voltage all inputs have 5v. Do you know in what way to look?
Gates board is working fine, only my first channel 1 led is always burning (only when connected with my midibox) but you can see it's triggering. All other channels are working like a charm.
Cheers niels
Edited by enveevee
+5V or -5V? Inputs or outputs? You mean you can't change the voltage of the outputs?
 If you followed the tutorial, the LEDs should glow red with negative voltage. Or did you use different LEDs?
How are you sourcing the +5V on the Euroceiver? Still over USB or with the regulator/jumper?
From the description, I think the DAC is not outputting any voltage, so the transmute8 board defaults to the -5V offset. This could be caused by
  • no +5V power
  • AOUT not configured (select module type AOUT)
  • cables/improper board-to-board connections/cable in wrong J19
  • missing RC1 jumpers
Even without any transmute8 board connected, you should be able to measure voltage from 0-2.048V from the output header when running through the calibration procedure.
Can you measure a voltage on the jack output? Maybe the gate output is configured as inverted on the AOUT SEQ menu? You can try another octal board. Check the soldering around R1/LED1/IC1.
