AINSER parallax mode
macsaif
Hello,
I am trying to understand the parallax mode of AINSER. I would like to use it, but in my case it works exactly as DIRECT function.
In NGC I am configuring the AINSER and the forwarded 2 SENDERs:
AINSER n=1 enabled=1 muxed=1 cs=1 resolution=7bit pinrange=3:10:4055
EVENT_AINSER id=3 hw_id=3 fwd_id=SENDER:3 range=0:127 no_dump=1 ain_mode= Snap
EVENT_SENDER id=3 hw_id=3 type=CC chn=1 cc=43 range=0:127 no_dump=0 ports=1111110000000000
EVENT_SENDER id=103 hw_id=3 type=CC chn=4 cc=43 range=0:127 no_dump=0 ports=1111110000000000
Based on the actual status of one button in .NGR I am activating Sender 3 or Sender 103 and copying its value back to AINSER.
It works correctly with SNAP function but if I change the SNAP to Parallax it jumps directly to the actual status of the potentiometer when I move with it (like the direct mode).
Can it be connected with the think that the AINSER works in range 0-4065 and the CC works in range 0-127?
What is a correct solution?
Frank
