NRPN issues - can't go past NRPN #256
weasel
hello friends,
i have a problem with my rotary encoders sending several banks of midi NRPN data - i can't go past NRPN number 256! the second byte of the midi nrpn number message (ie. midi CC 99) midibox sends only goes from 0 to 1, as shown on the mios studio output monitor.
it says in the manual that the nrpn number is also 14bit range as per the midi standard
nrpn=<0..16383> 	Specifies the NRPN number (0..16383) for type=NRPN events
is this a known issue? am i doing something wrong (presumably...)
this is an EVENT ENC definition that shows:
EVENT_ENC    id=  55 hw_id=7 bank=3  type=nrpn nrpn=261     chn= 1    range=  4095:0  enc_speed_mode=fast:6   offset=  0  ports=10001000000010000000  lcd_pos=1:1:1  label="^std_enc" value= 0
Quote
so, this give me CC99 = 1 CC98 = 5, NRPN = 133
instead of CC99 = 2 cc98 = 5, NRPN = 261
that i wanted. only the first bit of CC99 seems to be changed, effectively giving me 8bit range.
Edited by weasel
on the receiver side i am monitoring the midi incoming from the midibox with the axoxloti serial monitor, which shows the same value that mios studio shows sending.
so, mios studio seems to display the "correct" values that are actually being sent. just CC99 only ranges from 0-1 instead 0-127.
Anyway we will do a small debug test...
For that you will need to recompile the MBNG app after modification...
in mbng_file_c.c at line 812
replace this:
    } else if( strcasecmp(parameter, "nrpn") == 0 ) {
      int value;
      if( (value=get_dec(value_str)) < 0 || value >= 16384 ) {
#if DEBUG_VERBOSE_LEVEL >= 1
	DEBUG_MSG("[MBNG_FILE_C:%d] ERROR: invalid NRPN number in EVENT_%s ... %s=%s\n", line, event, parameter, value_str);
#endif
	return -1;
      } else {
	if( item.flags.type != MBNG_EVENT_TYPE_NRPN ) {
	  DEBUG_MSG("[MBNG_FILE_C:%d] WARNING: no NRPN number expected for EVENT_%s due to type: %s\n", line, event, MBNG_EVENT_ItemTypeStrGet(&item));
#endif
	} else {
	  // no extra check if event_type already defined...
	  stream[1] = value & 0xff;
	  stream[2] = value >> 8;
	  item.secondary_value = stream[1];
by
      int value;
#endif
	return -1;
      } else {
#endif
	} else {
	  stream[1] = value & 0x7f;
	  stream[2] = value >> 7;
Cause !
In this part of the parser there's something strange which is disturbing me at the end when the address is store in the item->stream we've got:
but in the MBNG_EVENT_TYPE_NRPN part of the MBNG_EVENT_ItemSend function we've got:
    u16 nrpn_address = item->stream[1] | ((u16)item->stream[2] << 7);
if I make the calculation like it is I find exactly your problem:
In parser
stream[1] = 261 & 0xff = 5
stream[2] = 261 >> 8 = 1
then in MBNG_EVENT_ItemSend
u16 nrpn_address = item->stream[1] | ((u16)item->stream[2] << 7) = 5 | (1<<7) = 133
Address msb is not limited to 0 or 1, I think it's a masking and shifting error and bit 7 is lost, so make the test with
Please
Edited by Antichambre
