"No free token memory"
jjonas
MIOS Studio gives me the following output when I load a setup:
[ 688.529] [MBNG_FILE_C] Event Pool Number of Items: 377
[ 688.530] [MBNG_FILE_C] Event Pool Allocation: 23353 of 65536 bytes (35%)
[ 689.336] [MBNG_FILE_R:214] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.339] [MBNG_FILE_R:215] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.339] [MBNG_FILE_R:216] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.339] [MBNG_FILE_R:217] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.339] [MBNG_FILE_R:218] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.339] [MBNG_FILE_R:219] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.341] [MBNG_FILE_R:221] ERROR: no free token memory anymore (16384 bytes allocated!)
[ 689.341] [MBNG_FILE_R:2781] stopped script execution due to previous error!
[ 689.374] First Bank
[ 689.374] [MBNG_FILE_R_Exec] ERROR: unsupported value at mem pos 0x4000!
The setup in question (for a different synth than in my other thread about sysex) has 336 NRPN encoder events, distributed in banks and into layer A and layer B within each bank by using NGR to deactivate and activate events. My other setup for sysex based control has more events (though it consumes a few percentage points less memory in the event pool than this one).
 When I comment out the biggest bank (2×4×16 = 128 events), the error output is gone. I realise this might be a limitation I just have to adapt to, but I post this in case it isn't.
linking this information with your proposal for "bulk operations", and it makes sense ;-)
Would "combined" set_active help to reduce the number of commands, or are there other commands which are repeating a lot?
Best Regards, Thorsten,
