Phatline Posted March 12, 2021 Report Posted March 12, 2021 on my Midibox CV Project, i make char-arry with alpabetical sorted Words --- which are Labels under Encoders to show you the Parameter names because its a modular project, i will make it easy via Drop-Down-menue to change the Labels on the fly for this i started a Excel (in order to sort alphabetical) looking like this: later i copy this block, into a text editor, replace automaticly the spaces, and copy paste it into the c program. may char array in C-Code will end up like this: char Label[512][8] = { {'a','b','c','d','e','f','g','h'}, {'i','j','k','l','m','n','o','p'}, {'q','r','e','s','t','u','v','w'}, {'1','2','3','4','5','6','7','8'}, .... }; my Font-Size only allow 8 Chars on a SSD1306 (128x64pix) i will report my list here, and if anyone has some idea which should be add (because its missing), then write it here. thx.
Phatline Posted March 12, 2021 Author Report Posted March 12, 2021 (edited) Labels.ods this is what i get : Quote 303 606 707 808 909 - * / + AMP AMP ENV AMP LFO AMP MSQ ADSR AMP ADSR AMMOUNT ATACK ACCENT ACID ARPGIATR AIN 1 AIN 2 AIN 3 AOUT 1 AOUT 2 AOUT 3 AOUT 4 AOUT 5 AOUT 6 AOUT 7 AOUT 8 AOUT 9 AOUT 10 AOUT 11 AOUT 12 AOUT 13 AOUT 14 AOUT 15 AOUT 16 ATTENUAT ATT AMPERE AIR AMBIANCE AND BPF BPF CUT BPF RES BPF ENV BPF ADSR BASEDRUM BASE BPM BEND BENDRNGE BASS BIAURAL BLUE BLACK BASE BRIGHTN BOTTUM BLACK BRIGHTN BRILLIAN CUT CUT ENV CUT LFO CUT MSQ CONGA CHEMBE CYMBAL COMPRESS CLAP CHORUS CTL CTL UP CTL DOWN CHANNEL CV CV MOD COMPRESS COMB FLT COURSE CHRD MEM CURVE CALIBRTE CONTROLL CLEARENC CLEAR CLEARENC CHANGE CYAN COLOR DRIVE DEPTH DISTORT DRY-WET DRY DRUM DUCKER DUCKING DECAY DETUNE DAMPING DRECK DELAY DLY TYPE DLY TIME DLY SYNC DETUNE DRIVE DIODESAT DEPTH DESTINAT DRAW DFM DEEPNESS DOUBLER DELY EQ EQ Q EQ GAIN ENVELOPE ENV AMT EMPTY FILTER FUZZ FUZZMULT FM FM GAIN FM MULTI FM VOICE FADE FEEDBACK FDBK FINE FB AMMNT FLANGER FM AMT GAIN GUITAR GLIDE GREEN GRAY GENERATO HPF HPF CUT HPF RES HPF ENV HPF ADSR HH OPEN HH CLOSE HI HAT HI TOM HANDCLAP HARMONIC HALLZEIT HALL BPF HALL HPF HALLFDBK HENRY HISS HI END HIGH HOLD INVERT INPUT JOYSTICK KICK KILL KEY KEY FOLW KEY LPF LPF CUT LPF RES LPF ENV LPF ADSR LO TOM LFO 1 LFO 2 LFO 3 LFO 4 LFO 5 LFO 6 LFO 7 LFO 8 LEVEL L-R LFO1 MOD LFO2 MOD LFO3 MOD LFO4 MOD LEAD LIMIT LIMITER LEGATO LINE LINE IN LUMEN LO END LOW ms MS MID TOM MAKE UP MORPH MOD MODWHEAL MULTIEFX MIX MIXDOWN MORPH MORPHING MONO MASHUP MODDEPTH MOD ENV MOD MODULATI MIDIBX MID MAGENTA MOJO NOISE NOISELVL NOISESEL nm NOTINUSE NAND OSC 1 OSC 2 OSC 3 OSC 4 OSC 5 OSC 6 OSC 9 OSC 10 OSC 11 OSC 12 OSC 13 OSC 14 OSC 15 OSC 16 OVRDRIVE OSC FINE OFFSET OFFSET OSC SHFT OSC PAN OVERDRIV OSC MIX OSC MOD OCT SHFT OUTPUT OPACITY OR PITCH PITCHWHL PULSEWDE PAN PAUSE PULSE PINKNOIS PWM PWM DEPT PORTAMEN PAD POLY PITCHSFT PART 1 PART 2 PART 3 PART 4 PART 5 PART 6 PART 7 PART 8 PHASE RES RINGMOD RATE RIDE RATIO REVERB RANDOM RND KILL RIM RIM SHOT RELEASE REC REVERB RANDOM RYTHM REMIX RESONATO REV FDBK RETURN RETRN FX RAMP RING RINGMOD RING OSC RED ROTATION SAMPLER SAMPLE SAMPLE 1 SAMPLE 2 SAMPLE 3 SAMPLE 4 SAMPLE 5 SAMPLE 6 SAMPLE 7 SAMPLE 8 START SMP STRT SMP STOP STOP SNARE SUSTAIN SWING STEP STEP FW STEP RW STEP + STEP - SYNC SYNC RTE SQARE STEREO SAW SAWTOOTH SINE SAW MOD SUPERSAW SAEURE SCHMUTZ SYNC SPHARE SEMITONE SCHNECK SCOPE SLIDE S&H SAMPaHLD SUMM SHAPE STELLA SID STELLAx4 SEND SEND EFX SIEMENS SOUL STERIL TIME TOM TOM LO TOM HI TOM MID TOMs TIME TUNE TUNE OSC TRI TRIANGLE TRI MOD TREEBLE TEMPO TRANSPOS TAPE TAPE SAT TUBE SAT TREMOLO TREMO GN TREMORTE TIMEWARP TUNER TESLA TOP TRASH UNISONO VERB WET VELOCITY VERBSIZE VOLUME VCA VCF VCO VCD VOLTAGE VOLT WET WHIDE WHITENOI WIDE WAVE WAVEFORM waveleng WHITE X4 XMORPH X MOD X-AXIS XOR Y-AXIS YELLOW YIELD YAW Z-AXIS ZEBRA gives a array of: Quote char Label[512][8] = { {'3','0','3',' ',' ',' ',' ',' '}, {'6','0','6',' ',' ',' ',' ',' '}, {'7','0','7',' ',' ',' ',' ',' '}, {'8','0','8',' ',' ',' ',' ',' '}, {'9','0','9',' ',' ',' ',' ',' '}, {'-',' ',' ',' ',' ',' ',' ',' '}, {'*',' ',' ',' ',' ',' ',' ',' '}, {'/',' ',' ',' ',' ',' ',' ',' '}, {'+',' ',' ',' ',' ',' ',' ',' '}, {'A','M','P',' ',' ',' ',' ',' '}, {'A','M','P',' ','E','N','V',' '}, {'A','M','P',' ','L','F','O',' '}, {'A','M','P',' ','M','S','Q',' '}, {'A','D','S','R',' ',' ',' ',' '}, {'A','M','P',' ','A','D','S','R'}, {'A','M','M','O','U','N','T',' '}, {'A','T','A','C','K',' ',' ',' '}, {'A','C','C','E','N','T',' ',' '}, {'A','C','I','D',' ',' ',' ',' '}, {'A','R','P','G','I','A','T','R'}, {'A','I','N',' ','1',' ',' ',' '}, {'A','I','N',' ','2',' ',' ',' '}, {'A','I','N',' ','3',' ',' ',' '}, {'A','O','U','T',' ','1',' ',' '}, {'A','O','U','T',' ','2',' ',' '}, {'A','O','U','T',' ','3',' ',' '}, {'A','O','U','T',' ','4',' ',' '}, {'A','O','U','T',' ','5',' ',' '}, {'A','O','U','T',' ','6',' ',' '}, {'A','O','U','T',' ','7',' ',' '}, {'A','O','U','T',' ','8',' ',' '}, {'A','O','U','T',' ','9',' ',' '}, {'A','O','U','T',' ','1','0',' '}, {'A','O','U','T',' ','1','1',' '}, {'A','O','U','T',' ','1','2',' '}, {'A','O','U','T',' ','1','3',' '}, {'A','O','U','T',' ','1','4',' '}, {'A','O','U','T',' ','1','5',' '}, {'A','O','U','T',' ','1','6',' '}, {'A','T','T','E','N','U','A','T'}, {'A','T','T',' ',' ',' ',' ',' '}, {'A','M','P','E','R','E',' ',' '}, {'A','I','R',' ',' ',' ',' ',' '}, {'A','M','B','I','A','N','C','E'}, {'A','N','D',' ',' ',' ',' ',' '}, {'B','P','F',' ',' ',' ',' ',' '}, {'B','P','F',' ','C','U','T',' '}, {'B','P','F',' ','R','E','S',' '}, {'B','P','F',' ','E','N','V',' '}, {'B','P','F',' ','A','D','S','R'}, {'B','A','S','E','D','R','U','M'}, {'B','A','S','E',' ',' ',' ',' '}, {'B','P','M',' ',' ',' ',' ',' '}, {'B','E','N','D',' ',' ',' ',' '}, {'B','E','N','D','R','N','G','E'}, {'B','A','S','S',' ',' ',' ',' '}, {'B','I','A','U','R','A','L',' '}, {'B','L','U','E',' ',' ',' ',' '}, {'B','L','A','C','K',' ',' ',' '}, {'B','A','S','E',' ',' ',' ',' '}, {'B','R','I','G','H','T','N',' '}, {'B','O','T','T','U','M',' ',' '}, {'B','L','A','C','K',' ',' ',' '}, {'B','R','I','G','H','T','N',' '}, {'B','R','I','L','L','I','A','N'}, {'C','U','T',' ',' ',' ',' ',' '}, {'C','U','T',' ','E','N','V',' '}, {'C','U','T',' ','L','F','O',' '}, {'C','U','T',' ','M','S','Q',' '}, {'C','O','N','G','A',' ',' ',' '}, {'C','H','E','M','B','E',' ',' '}, {'C','Y','M','B','A','L',' ',' '}, {'C','O','M','P','R','E','S','S'}, {'C','L','A','P',' ',' ',' ',' '}, {'C','H','O','R','U','S',' ',' '}, {'C','T','L',' ',' ',' ',' ',' '}, {'C','T','L',' ','U','P',' ',' '}, {'C','T','L',' ','D','O','W','N'}, {'C','H','A','N','N','E','L',' '}, {'C','V',' ',' ',' ',' ',' ',' '}, {'C','V',' ','M','O','D',' ',' '}, {'C','O','M','P','R','E','S','S'}, {'C','O','M','B',' ','F','L','T'}, {'C','O','U','R','S','E',' ',' '}, {'C','H','R','D',' ','M','E','M'}, {'C','U','R','V','E',' ',' ',' '}, {'C','A','L','I','B','R','T','E'}, {'C','O','N','T','R','O','L','L'}, {'C','L','E','A','R','E','N','C'}, {'C','L','E','A','R',' ',' ',' '}, {'C','L','E','A','R','E','N','C'}, {'C','H','A','N','G','E',' ',' '}, {'C','Y','A','N',' ',' ',' ',' '}, {'C','O','L','O','R',' ',' ',' '}, {'D','R','I','V','E',' ',' ',' '}, {'D','E','P','T','H',' ',' ',' '}, {'D','I','S','T','O','R','T',' '}, {'D','R','Y','-','W','E','T',' '}, {'D','R','Y',' ',' ',' ',' ',' '}, {'D','R','U','M',' ',' ',' ',' '}, {'D','U','C','K','E','R',' ',' '}, {'D','U','C','K','I','N','G',' '}, {'D','E','C','A','Y',' ',' ',' '}, {'D','E','T','U','N','E',' ',' '}, {'D','A','M','P','I','N','G',' '}, {'D','R','E','C','K',' ',' ',' '}, {'D','E','L','A','Y',' ',' ',' '}, {'D','L','Y',' ','T','Y','P','E'}, {'D','L','Y',' ','T','I','M','E'}, {'D','L','Y',' ','S','Y','N','C'}, {'D','E','T','U','N','E',' ',' '}, {'D','R','I','V','E',' ',' ',' '}, {'D','I','O','D','E','S','A','T'}, {'D','E','P','T','H',' ',' ',' '}, {'D','E','S','T','I','N','A','T'}, {'D','R','A','W',' ',' ',' ',' '}, {'D','F','M',' ',' ',' ',' ',' '}, {'D','E','E','P','N','E','S','S'}, {'D','O','U','B','L','E','R',' '}, {'D','E','L','Y',' ',' ',' ',' '}, {'E','Q',' ',' ',' ',' ',' ',' '}, {'E','Q',' ','Q',' ',' ',' ',' '}, {'E','Q',' ','G','A','I','N',' '}, {'E','N','V','E','L','O','P','E'}, {'E','N','V',' ','A','M','T',' '}, {'E','M','P','T','Y',' ',' ',' '}, {'F','I','L','T','E','R',' ',' '}, {'F','U','Z','Z',' ',' ',' ',' '}, {'F','U','Z','Z','M','U','L','T'}, {'F','M',' ',' ',' ',' ',' ',' '}, {'F','M',' ','G','A','I','N',' '}, {'F','M',' ','M','U','L','T','I'}, {'F','M',' ','V','O','I','C','E'}, {'F','A','D','E',' ',' ',' ',' '}, {'F','E','E','D','B','A','C','K'}, {'F','D','B','K',' ',' ',' ',' '}, {'F','I','N','E',' ',' ',' ',' '}, {'F','B',' ','A','M','M','N','T'}, {'F','L','A','N','G','E','R',' '}, {'F','M',' ','A','M','T',' ',' '}, {'G','A','I','N',' ',' ',' ',' '}, {'G','U','I','T','A','R',' ',' '}, {'G','L','I','D','E',' ',' ',' '}, {'G','R','E','E','N',' ',' ',' '}, {'G','R','A','Y',' ',' ',' ',' '}, {'G','E','N','E','R','A','T','O'}, {'H','P','F',' ',' ',' ',' ',' '}, {'H','P','F',' ','C','U','T',' '}, {'H','P','F',' ','R','E','S',' '}, {'H','P','F',' ','E','N','V',' '}, {'H','P','F',' ','A','D','S','R'}, {'H','H',' ','O','P','E','N',' '}, {'H','H',' ','C','L','O','S','E'}, {'H','I',' ','H','A','T',' ',' '}, {'H','I',' ','T','O','M',' ',' '}, {'H','A','N','D','C','L','A','P'}, {'H','A','R','M','O','N','I','C'}, {'H','A','L','L','Z','E','I','T'}, {'H','A','L','L',' ','B','P','F'}, {'H','A','L','L',' ','H','P','F'}, {'H','A','L','L','F','D','B','K'}, {'H','E','N','R','Y',' ',' ',' '}, {'H','I','S','S',' ',' ',' ',' '}, {'H','I',' ','E','N','D',' ',' '}, {'H','I','G','H',' ',' ',' ',' '}, {'H','O','L','D',' ',' ',' ',' '}, {'I','N','V','E','R','T',' ',' '}, {'I','N','P','U','T',' ',' ',' '}, {'J','O','Y','S','T','I','C','K'}, {'K','I','C','K',' ',' ',' ',' '}, {'K','I','L','L',' ',' ',' ',' '}, {'K','E','Y',' ',' ',' ',' ',' '}, {'K','E','Y',' ','F','O','L','W'}, {'K','E','Y',' ',' ',' ',' ',' '}, {'L','P','F',' ',' ',' ',' ',' '}, {'L','P','F',' ','C','U','T',' '}, {'L','P','F',' ','R','E','S',' '}, {'L','P','F',' ','E','N','V',' '}, {'L','P','F',' ','A','D','S','R'}, {'L','O',' ','T','O','M',' ',' '}, {'L','F','O',' ','1',' ',' ',' '}, {'L','F','O',' ','2',' ',' ',' '}, {'L','F','O',' ','3',' ',' ',' '}, {'L','F','O',' ','4',' ',' ',' '}, {'L','F','O',' ','5',' ',' ',' '}, {'L','F','O',' ','6',' ',' ',' '}, {'L','F','O',' ','7',' ',' ',' '}, {'L','F','O',' ','8',' ',' ',' '}, {'L','E','V','E','L',' ',' ',' '}, {'L','-','R',' ',' ',' ',' ',' '}, {'L','F','O','1',' ','M','O','D'}, {'L','F','O','2',' ','M','O','D'}, {'L','F','O','3',' ','M','O','D'}, {'L','F','O','4',' ','M','O','D'}, {'L','E','A','D',' ',' ',' ',' '}, {'L','I','M','I','T',' ',' ',' '}, {'L','I','M','I','T','E','R',' '}, {'L','E','G','A','T','O',' ',' '}, {'L','I','N','E',' ',' ',' ',' '}, {'L','I','N','E',' ','I','N',' '}, {'L','U','M','E','N',' ',' ',' '}, {'L','O',' ','E','N','D',' ',' '}, {'L','O','W',' ',' ',' ',' ',' '}, {'m','s',' ',' ',' ',' ',' ',' '}, {'M','S',' ',' ',' ',' ',' ',' '}, {'M','I','D',' ','T','O','M',' '}, {'M','A','K','E',' ','U','P',' '}, {'M','O','R','P','H',' ',' ',' '}, {'M','O','D',' ',' ',' ',' ',' '}, {'M','O','D','W','H','E','A','L'}, {'M','U','L','T','I','E','F','X'}, {'M','I','X',' ',' ',' ',' ',' '}, {'M','I','X','D','O','W','N',' '}, {'M','O','R','P','H',' ',' ',' '}, {'M','O','R','P','H','I','N','G'}, {'M','O','N','O',' ',' ',' ',' '}, {'M','A','S','H','U','P',' ',' '}, {'M','O','D','D','E','P','T','H'}, {'M','O','D',' ','E','N','V',' '}, {'M','O','D',' ',' ',' ',' ',' '}, {'M','O','D','U','L','A','T','I'}, {'M','I','D','I','B','X',' ',' '}, {'M','I','D',' ',' ',' ',' ',' '}, {'M','A','G','E','N','T','A',' '}, {'M','O','J','O',' ',' ',' ',' '}, {'N','O','I','S','E',' ',' ',' '}, {'N','O','I','S','E','L','V','L'}, {'N','O','I','S','E','S','E','L'}, {'n','m',' ',' ',' ',' ',' ',' '}, {'N','O','T','I','N','U','S','E'}, {'N','A','N','D',' ',' ',' ',' '}, {'O','S','C',' ','1',' ',' ',' '}, {'O','S','C',' ','2',' ',' ',' '}, {'O','S','C',' ','3',' ',' ',' '}, {'O','S','C',' ','4',' ',' ',' '}, {'O','S','C',' ','5',' ',' ',' '}, {'O','S','C',' ','6',' ',' ',' '}, {'O','S','C',' ','9',' ',' ',' '}, {'O','S','C',' ','1','0',' ',' '}, {'O','S','C',' ','1','1',' ',' '}, {'O','S','C',' ','1','2',' ',' '}, {'O','S','C',' ','1','3',' ',' '}, {'O','S','C',' ','1','4',' ',' '}, {'O','S','C',' ','1','5',' ',' '}, {'O','S','C',' ','1','6',' ',' '}, {'O','V','R','D','R','I','V','E'}, {'O','S','C',' ','F','I','N','E'}, {'O','F','F','S','E','T',' ',' '}, {'O','F','F','S','E','T',' ',' '}, {'O','S','C',' ','S','H','F','T'}, {'O','S','C',' ','P','A','N',' '}, {'O','V','E','R','D','R','I','V'}, {'O','S','C',' ','M','I','X',' '}, {'O','S','C',' ','M','O','D',' '}, {'O','C','T',' ','S','H','F','T'}, {'O','U','T','P','U','T',' ',' '}, {'O','P','A','C','I','T','Y',' '}, {'O','R',' ',' ',' ',' ',' ',' '}, {'P','I','T','C','H',' ',' ',' '}, {'P','I','T','C','H','W','H','L'}, {'P','U','L','S','E','W','D','E'}, {'P','A','N',' ',' ',' ',' ',' '}, {'P','A','U','S','E',' ',' ',' '}, {'P','U','L','S','E',' ',' ',' '}, {'P','I','N','K','N','O','I','S'}, {'P','W','M',' ',' ',' ',' ',' '}, {'P','W','M',' ','D','E','P','T'}, {'P','O','R','T','A','M','E','N'}, {'P','A','D',' ',' ',' ',' ',' '}, {'P','O','L','Y',' ',' ',' ',' '}, {'P','I','T','C','H','S','F','T'}, {'P','A','R','T',' ','1',' ',' '}, {'P','A','R','T',' ','2',' ',' '}, {'P','A','R','T',' ','3',' ',' '}, {'P','A','R','T',' ','4',' ',' '}, {'P','A','R','T',' ','5',' ',' '}, {'P','A','R','T',' ','6',' ',' '}, {'P','A','R','T',' ','7',' ',' '}, {'P','A','R','T',' ','8',' ',' '}, {'P','H','A','S','E',' ',' ',' '}, {'R','E','S',' ',' ',' ',' ',' '}, {'R','I','N','G','M','O','D',' '}, {'R','A','T','E',' ',' ',' ',' '}, {'R','I','D','E',' ',' ',' ',' '}, {'R','A','T','I','O',' ',' ',' '}, {'R','E','V','E','R','B',' ',' '}, {'R','A','N','D','O','M',' ',' '}, {'R','N','D',' ','K','I','L','L'}, {'R','I','M',' ',' ',' ',' ',' '}, {'R','I','M',' ','S','H','O','T'}, {'R','E','L','E','A','S','E',' '}, {'R','E','C',' ',' ',' ',' ',' '}, {'R','E','V','E','R','B',' ',' '}, {'R','A','N','D','O','M',' ',' '}, {'R','Y','T','H','M',' ',' ',' '}, {'R','E','M','I','X',' ',' ',' '}, {'R','E','S','O','N','A','T','O'}, {'R','E','V',' ','F','D','B','K'}, {'R','E','T','U','R','N',' ',' '}, {'R','E','T','R','N',' ','F','X'}, {'R','A','M','P',' ',' ',' ',' '}, {'R','I','N','G',' ',' ',' ',' '}, {'R','I','N','G','M','O','D',' '}, {'R','I','N','G',' ','O','S','C'}, {'R','E','D',' ',' ',' ',' ',' '}, {'R','O','T','A','T','I','O','N'}, {'S','A','M','P','L','E','R',' '}, {'S','A','M','P','L','E',' ',' '}, {'S','A','M','P','L','E',' ','1'}, {'S','A','M','P','L','E',' ','2'}, {'S','A','M','P','L','E',' ','3'}, {'S','A','M','P','L','E',' ','4'}, {'S','A','M','P','L','E',' ','5'}, {'S','A','M','P','L','E',' ','6'}, {'S','A','M','P','L','E',' ','7'}, {'S','A','M','P','L','E',' ','8'}, {'S','T','A','R','T',' ',' ',' '}, {'S','M','P',' ','S','T','R','T'}, {'S','M','P',' ','S','T','O','P'}, {'S','T','O','P',' ',' ',' ',' '}, {'S','N','A','R','E',' ',' ',' '}, {'S','U','S','T','A','I','N',' '}, {'S','W','I','N','G',' ',' ',' '}, {'S','T','E','P',' ',' ',' ',' '}, {'S','T','E','P',' ','F','W',' '}, {'S','T','E','P',' ','R','W',' '}, {'S','T','E','P',' ','+',' ',' '}, {'S','T','E','P',' ','-',' ',' '}, {'S','Y','N','C',' ',' ',' ',' '}, {'S','Y','N','C',' ','R','T','E'}, {'S','Q','A','R','E',' ',' ',' '}, {'S','T','E','R','E','O',' ',' '}, {'S','A','W',' ',' ',' ',' ',' '}, {'S','A','W','T','O','O','T','H'}, {'S','I','N','E',' ',' ',' ',' '}, {'S','A','W',' ','M','O','D',' '}, {'S','U','P','E','R','S','A','W'}, {'S','A','E','U','R','E',' ',' '}, {'S','C','H','M','U','T','Z',' '}, {'S','Y','N','C',' ',' ',' ',' '}, {'S','P','H','A','R','E',' ',' '}, {'S','E','M','I','T','O','N','E'}, {'S','C','H','N','E','C','K',' '}, {'S','C','O','P','E',' ',' ',' '}, {'S','L','I','D','E',' ',' ',' '}, {'S','&','H',' ',' ',' ',' ',' '}, {'S','A','M','P','a','H','L','D'}, {'S','U','M','M',' ',' ',' ',' '}, {'S','H','A','P','E',' ',' ',' '}, {'S','T','E','L','L','A',' ',' '}, {'S','I','D',' ',' ',' ',' ',' '}, {'S','T','E','L','L','A','x','4'}, {'S','E','N','D',' ',' ',' ',' '}, {'S','E','N','D',' ','E','F','X'}, {'S','I','E','M','E','N','S',' '}, {'S','O','U','L',' ',' ',' ',' '}, {'S','T','E','R','I','L',' ',' '}, {'T','I','M','E',' ',' ',' ',' '}, {'T','O','M',' ',' ',' ',' ',' '}, {'T','O','M',' ','L','O',' ',' '}, {'T','O','M',' ','H','I',' ',' '}, {'T','O','M',' ','M','I','D',' '}, {'T','O','M','s',' ',' ',' ',' '}, {'T','I','M','E',' ',' ',' ',' '}, {'T','U','N','E',' ',' ',' ',' '}, {'T','U','N','E',' ','O','S','C'}, {'T','R','I',' ',' ',' ',' ',' '}, {'T','R','I','A','N','G','L','E'}, {'T','R','I',' ','M','O','D',' '}, {'T','R','E','E','B','L','E',' '}, {'T','E','M','P','O',' ',' ',' '}, {'T','R','A','N','S','P','O','S'}, {'T','A','P','E',' ',' ',' ',' '}, {'T','A','P','E',' ','S','A','T'}, {'T','U','B','E',' ','S','A','T'}, {'T','R','E','M','O','L','O',' '}, {'T','R','E','M','O',' ','G','N'}, {'T','R','E','M','O','R','T','E'}, {'T','I','M','E','W','A','R','P'}, {'T','U','N','E','R',' ',' ',' '}, {'T','E','S','L','A',' ',' ',' '}, {'T','O','P',' ',' ',' ',' ',' '}, {'T','R','A','S','H',' ',' ',' '}, {'U','N','I','S','O','N','O',' '}, {'V','E','R','B',' ','W','E','T'}, {'V','E','L','O','C','I','T','Y'}, {'V','E','R','B','S','I','Z','E'}, {'V','O','L','U','M','E',' ',' '}, {'V','C','A',' ',' ',' ',' ',' '}, {'V','C','F',' ',' ',' ',' ',' '}, {'V','C','O',' ',' ',' ',' ',' '}, {'V','C','D',' ',' ',' ',' ',' '}, {'V','O','L','T','A','G','E',' '}, {'V','O','L','T',' ',' ',' ',' '}, {'W','E','T',' ',' ',' ',' ',' '}, {'W','H','I','D','E',' ',' ',' '}, {'W','H','I','T','E','N','O','I'}, {'W','I','D','E',' ',' ',' ',' '}, {'W','A','V','E',' ',' ',' ',' '}, {'W','A','V','E','F','O','R','M'}, {'w','a','v','e','l','e','n','g'}, {'W','H','I','T','E',' ',' ',' '}, {'X','4',' ',' ',' ',' ',' ',' '}, {'X','M','O','R','P','H',' ',' '}, {'X',' ','M','O','D',' ',' ',' '}, {'X','-','A','X','I','S',' ',' '}, {'X','O','R',' ',' ',' ',' ',' '}, {'Y','-','A','X','I','S',' ',' '}, {'Y','E','L','L','O','W',' ',' '}, {'Y','I','E','L','D',' ',' ',' '}, {'Y','A','W',' ',' ',' ',' ',' '}, {'Z','-','A','X','I','S',' ',' '}, {'Z','E','B','R','A',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}, {' ',' ',' ',' ',' ',' ',' ',' '}}; Edited March 13, 2021 by Phatline
