Korg Poly-61 MIDIbox Upgrade, Poly-61MB.
Antichambre
Hi all,
I place this project here baecause it's more than a simple midification of a vintage synth.
Here is the only existing post which talk about this subject here
It already exists a few retro kit for the Korg Poly-61, but i wanted to fully upgrade my old Poly-61.
It's a synth I owned for free, it was found at the back of a concert hall, in the trash. I fixed and renovate it.
Symptoms were the common ones, battery leakage on the porgrammer board, wood parts and some keys were destroyed.
Once it was fixed I got a lot of fun with it, it sounds typically 80s with a fat analog vibe and i love that.
but using MIDI for pretty everything I was very frustrated by the lack of midi control and it's limited control panel.
So I started to study something better.
I replaced all the digital part of the synth by a MIDIbox based one, I kept all the signal path like it is.
I also reuse the existing control panel
I recreate the exact behavior of the original one in MIOS32, named LEGACY mode, the original factory presets were implemented too.
The useless TAPE ENABLE switch at the back is now a switch between the LEGACY mode and the EXTENDED mode, it enhances the parameters ranges and adds some new parameters.
Finally I designed a dedicated Control surface which can be directly connected and powered to/by the Poly using USB.
The Poly has an USB device port to connect to a daw and an Host port to connect a MIDI controller.
large.1284287475_IMG_4705-copie.jpg.2064f7d23f033d8bc4116fbfb0afbad2.jpglarge.564403821_IMG_4707-copie.jpg.60209b1165ba214017331da1aaf5f368.jpg
Voilà!
Best Regards
Bruno
  • 3 weeks later...
  • 1 year later...
