Guest djDim Posted November 14, 2002 Report Share Posted November 14, 2002 Hi,Is it possible to add normal buttons on unused encoder inputs of a midibox16E?Will the pic be able to treat them a midion/off commands?Thanks Quote Link to comment Share on other sites More sharing options...
TK. Posted November 15, 2002 Report Share Posted November 15, 2002 No, this isn't possible with MB16E, but it will be supported by MIDIbox NG where encoders and buttons are sampled on the same shiftregister chain.However, there is a workaround: if you plan to build a DINX4, and want to connect (lets say...) 8 encoders and 16 buttons, you can cut the SO; SC and RC track between IC2 and IC3 and connect one half to port J7 of the core module (encoders) and the other half to port J9 of the core module (buttons).Just handle it like 2 seperate DINX2 modules...(the power tracks have to be connected only once)Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
Guest bolotov Posted November 26, 2002 Report Share Posted November 26, 2002 Ich habe aber nicht verstanden, was und wo connect?(S0 u.s.w.) Quote Link to comment Share on other sites More sharing options...
