Compatibility Wilba control surface with Core407V
Polykobol
Dear all,
I first wish you all an happy new year and a lot of creativity for this year.
I did a long DIY and music pause due to professional reason.  I have few Sequencer V4 and some Core are damaged.
I think that the Midiphy solution is amazing but as I already have panels, cases, VFD Displays,  and control surface I would prefer to continu to
use them. Another reason, I prefer to have a small unit than a monster device. In this way as well, I would re-use theses tools and instruments and it would still be possible in future to upgrade to the Midiphy solution. But to send directly to the trash devices is to my taste not acceptable.
If I would buy the following Midify PCBs, would it be possible to run the Sequencer based on Wilba control panel with these boards?
1) PCB Core
2) SD PCB
3) MIDI 8 PCB
4) I2C PCB
5) Line TX PCB
6) Line RX PCB
Thanks,
F
Edited by Polykobol
nope that is a plastic case made by ponoko... so why you dont post the panel - else i am out!
why you want to use the midiphy core? use the orginal core? I ask because i have booth at home the lpc17 core (need different packbanel) the stm32F4 core '(need different backpanel)... the orginal stm32F4 core use the same microcontroller on a different developement board - like the waveshare from midiphy... ... i too have the linedriver pcb... i have a whole midibox labor with assembled modules at home - but if you wont show the backpanel - i cant help you anyway...
Edited by Phatline
tirol... oberösterreich - ok englisch ist nicht dein ding -
guad ich will doch nur die Anschlussblende sehen aka Backpanel
diese Rückansicht z.B.
 ist für ein core stm32F4... und ist offensichtlich für 2x Midi IO Module geschaffen
für diese ausführung hätte ich alles daheim, bis auf das zweite MIDI IO...
Well, I work using English since 1995.
I don't have any back Panel on this one. On the silver one I have a side Panel, but it is not here right now.
I want to get the maximal Midi port amount as possible. I would like to update as well with the the CV/Gate directly but for the beginning, it is not a must. SD port on the back as well. Sync Roland for old drum/Sequencers.
Isn't it possible to use the midi8 PCBs from Midiphy?
https://www.midiphy.com/en/shop-details/138/7/midi8-pcb-
ok kenn mich aus... das panel wird erst entworfen
natürlich möglich ist so wie ich das sehe ist das einfach ein http://www.ucapps.de/mbhp_midi_io.html
nur halt 2 auf einer platine
die line driver von midiphy kannst auch verwenden (obwohl ich einen da hätte den ich nicht mehr brauche - weil ich zwei habe)
vom  midiphy core her weis i ned-  müsste pin compatibel zum Discovery Board sein. - aber das orginal könntest auch von mir haben.  http://www.ucapps.de/mbhp_core_stm32f4.html
da wäre halt sd slot und usb gleich auf einem board... musst selber nachmessen was von der größe her eher in dein Wunschgehäuse und Anschluss Panel passt.
@ gate: direkt aus dem gehäuse... ja entweder via Linedriver für extern - oder via DINX4 intern http://www.ucapps.de/mbhp_din.html
oder du baust dir  https://www.midiphy.com/en/shop-details/121/50/seq-v4-eurorack-modules-essential-kit-midiphy-seq-v4-eurorack-modular-midi-cv-interface
direkt ins gehäuse.
für CV eben auch das midiphy module, oder halt. http://www.midibox.org/dokuwiki/aout_ng   und dann verkabeln zu buchsen ihrgendwo im gehäuse
(da hät ich was daheim falls die auflösung für dich reicht)
in beiden fällen brauchst halt dann im sequencer die +-12V um das CV von 3V raufzuskalieren zu verwendbaren werten...
