FantomXR Posted September 2, 2022 Report Posted September 2, 2022 (edited) Hey, I'm trying to split an incoming MIDI signal into two zones just like this: EVENT_RECEIVER id=1 type=NoteOn key=any fwd_id=SENDER:1 range=0:36 EVENT_SENDER id=1 type=NoteOn key=any range=0:36 chn=1 ports=100010000000 EVENT_RECEIVER id=2 type=NoteOn key=any fwd_id=SENDER:2 range=36:127 EVENT_SENDER id=2 type=NoteOn key=any range=37:127 chn=2 ports=100010000000 Unfortunately the "range" parameter has absolutely no effect here. Regardless what values I enter, it does output two NoteOns for each key (one on ch.1 the other on ch.2) over the whole range. It does have an effect on the velocity though. I could limit the velocity through the range-parameter. But thats not what I want to do :-) Is that a bug in the firmware? And if yes, who can fix it? :-) Thanks, Chris Edited September 2, 2022 by FantomXR Quote
Zam Posted September 2, 2022 Report Posted September 2, 2022 Hi Chris IIRC range= is not a split but a scale function, so range=0:36 change value 0-->0, 127-->36 and linear ponderation in-between. maybe try with conditional function, if_= Cheers Zam Quote
FantomXR Posted September 2, 2022 Author Report Posted September 2, 2022 1 hour ago, Zam said: Hi Chris IIRC range= is not a split but a scale function, so range=0:36 change value 0-->0, 127-->36 and linear ponderation in-between. maybe try with conditional function, if_= Cheers Zam Thanks for your reply. How could "if_" help here? What I now did (and what worked) is to create an EVENT_RECEIVER for every single note like EVENT_RECEIVER id=1 type=NoteOn key=20 fwd_id=SENDER:1 EVENT_RECEIVER id=1 type=NoteOn key=21 fwd_id=SENDER:1 EVENT_RECEIVER id=1 type=NoteOn key=22 fwd_id=SENDER:1 Since they all listen to the same ID, its easy to activate / deactivate that with meta events. This is not beautiful because it's a lot of code. But at least its a working solution ;-) Quote
Zam Posted September 2, 2022 Report Posted September 2, 2022 2 hours ago, FantomXR said: How could "if_" help here? it's a conditional, it will activate the event according to value don't remember precise form, I don't write NGC since years now, but something like if_less=37, your receiver will forward only data from 0 to 36 Quote
FantomXR Posted September 6, 2022 Author Report Posted September 6, 2022 On 9/2/2022 at 5:51 PM, Zam said: it's a conditional, it will activate the event according to value don't remember precise form, I don't write NGC since years now, but something like if_less=37, your receiver will forward only data from 0 to 36 This might also be valid only for the velocity but I'll give it a try! Quote
