bosone Posted May 19, 2004 Report Share Posted May 19, 2004 regrading this picture on www.ucapps.dei wonder if the differend cores can load different MIOS applications.for example, i plan to put the sequencer (with all his control surface...) and 2 SIDs in the same rack case.is it possible to chain the three cores and control both the sids and the sequencer with same control surface??how are the different menu handled?should i customize the MIOS code? Quote Link to comment Share on other sites More sharing options...
LO Posted May 19, 2004 Report Share Posted May 19, 2004 Think that it possible ......but to have it work with 1 LCD and 1 menu nav needs lots of coding I think.I was tring to sort this a while ago but do not have enough mios knowledge yet!good luck ;) Quote Link to comment Share on other sites More sharing options...
