Broccoli18 and Bootloader - SUCCESS!!!
Hi everyone!
After endless tries to get JDM+IC-Prog working i tried broccoli18 hardware and software 0.7 (XP port) and got immediate success. :D
Instructions on broccoli18 site are neary dumb save, it's an LVP mode programmer on LPT port i powered with 2 AA batteries. Used parts: PIC socket, wire, 0,1uF elko (50V), 330 Ohm resistor. It was up running and programming an 18F452 and an 18LF452 within one hour, soldering on an breadboard inclusive.
I sucessfully burned both demo hex files, so PICs and programmer are both well and running. ;D
***PS:READ THE FOLLOWING POSTS FOR THE SOLUTION!***
Now the question:
when trying to burn the bootloader with broccoli18 i got the following output:
Detecting PIC... Found PIC18F452.
Using hex file boot.hex.
Reading hex file...
Erasing memory from 0 to 32504...
Programming memory from 0 to 32504...
Erasing ID locations...
Programming ID locations 0 to 8...
Programming configuration bytes 0-13...
pic_verify_cfg: Cfg byte 6 doesn't match
Error in pic_setcfg: No such file or directory (ENOENT)
I loaded the bootloader 1.1b of MIOS into IC-Prog and saved in IHX8 format.
Burned this with the same result.
Is the bootloader hex file corrupt? Did i forget something to do?
Why does this program complain about Cfg byte 6? Is there anything very special about this bootloader that is "non standard"? ???
Any hint appreciated.
I can't try the PICs in a core, it's not built yet because i wanted to have a programmer before building any further (next projects will be a MBSid and MBSEQ_V2). :-[
I'm pretty sure the programmer works correctly since there's no fault in an even bigger demo hex.
Thorsten, maybe you can you bring a little light into my thoughts about this Cfg byte thingie?
Martin
Link to comment
Share on other sites
  • Replies 84
  • Created
  • Last Reply
Top Posters In This Topic
I',m not sure if a LVP programmer is really helpful, since it will disable pin RB5 for common use. This means that you won't be able to drive a LCD.
I'm also not sure about the error messages. The .hex file is definitely not corrupt, it is generated from the official assembler from Microchip, and it works with the PICstart programmer (the official PIC burner from Microchip...) as well as with IC-Prog. So I guess that the Briccoli software has an imperfection, maybe it's better to ask the name of this program for help.
Link to comment
Thanks for the prompt reply, Thorsten!
I will immediately change the mode of my broccoli to high voltage programming, it just needs VPP/MCLR to stay unconnected from the parallel port and use a 9V battery between ground and VPP, will be no problem...
Mmmmh i definetely don't know much about PICs, thanks for this advice! I definetely want to use an LCD!
I mailed Dave Sullins for the programs output already, awaiting an answer. Since then i will try to peek into the source since i'm a fairly well computer programmer  :)
I will post any forthcomings here...
and begin to build the first core module for testing the PICs.
(I have 6 PICs waiting to be powered by MIOS...)
Many thanks
Martin
Link to comment
HOW TO:
- Disconnect PIC Pin1 from the parallel port.
- 9 V battery: + to Pin1 (MCLR/VPP), - to ground
- "erasepic" (to be sure: twice! My programmer didn't get it the first time)
- burn bootloader
-smile 8)
WHY:
Thorsten brought me to the conclusion that it is silly to use LVP here and he was completely right. For the PIC 18(L)F452 i needed 9V on MCLR/VPP to ERASE the chip. since the "erasepic.exe" doesn't show any messages i thought the pic was erased as i used broccoli in LVP but i was WRONG. :P  Cfg byte 6 contains WRITE PROTECTION information, so in LVP i was not able to burn the configuration bytes because they were WRITE PROTECTED as i got them from Microchip!!! :o So they had to fail in the verification!
This is the result of the configuration change:
write protected fresh chip from microchip:
Configuration bits 00 26 0f 0f 00 01 85 00 0f c0 0f e0 0f 40
erased and new configurated chip:
Configuration bits 00 26 0f 0f 00 01 81 00 0f c0 0f e0 0f 40
Now i get pretty verified bootloader PICs!!! 8)
Thank you so much for your hint, Thorsten!
My programmer was pretty right, just programming in the false mode!
I hope that a lot of people who can't get JDM going give this programmer a try! This one is surely the cheapest and easyest solution to burn a few 18(L)F452.
NEEDS:
- 0,1uF Cap
- 330 Ohm resistor
- 2 AA or other 1,5V batteries
- 1 9V E-Block
- 1 old printer cable (you got that...)
- broccoli18-0.7.zip (XP port) (google for dave sullivan, broccoli18)
- wire, breadboard, a little bit of time and a multimeter, read the instrucions on Dave Sullivan's site
After building and measuring (very easy!):
- readcfg.exe (a few times, your PIC should be reliably identified)
- erasepic.exe (2 times to be sure, kill all those nasty write protection)
- writepic.exe bootloadername.hex
That's all!
Best regards
Martin
Link to comment
This sounds very good!
I will announce this in the news section. Once more than 10 people were able to burn their PIC successfully with this programmer, I will discontinue the MBHP_JDM and strongly recomment this much simpler one!
Link to comment
moebius, you are absolutely right!
In fact i built it out of garbage because i was so frustrated about my misbuilt JDM... ...i soldered the cable direcly to the elko corpus because i broke it off a pcb in anger about jdm, the resistor was knipex-ed from an old pcb... The breadboard doesnt even has solder points but i wanted to fix the batteries and the heavy cable ending of the destroyed printer cable with gaffa...ending up using "Tesa Film" :P
To anyone building this baby...consider using a 9V wall wart (check voltage, often they are overdozed), after burning around a dozen chips my 9V E-Block was down to 6V...burning failed at chip 13 :o
Programming time is long (maybe 3-4 minutes) but we do it just one time per pic so what...
Another point is: be aware of your port voltage (mine was approx. 4.5 V) and *calculate* your resistor, OK? ::)
Use the portdiag utility to make sure everythings right, if you have probs under XP use "UserPort" utility, not the mentioned packet from Dave Sullivans site, it is much more comfortable and absolutely reliable. In fact i had it running because i gave JDM a last chance with it and forgot to close it as i assembled my garbage can...so broccoli ran instantly after configuring the printer port. all people using linux will be happy to get a native tool ;D
By the way, i was pretty astonished it worked because the cable is way more than a meter long, i directly soldered the ends to the socket...
Martin
Link to comment
I'm also taking suggestions about the most creative use of a JDM board (besides it's intended use).
damm, these pcb´s look great.
Even i just made my diploma as artist i have no creative idea what to do with these. I have some misroutet pcb´s which i etched, but they are just lying in a dirty box, and thats quite boring.
All the best luck to your jdm boards, may they rest in peace.
chriss
Link to comment
  • 2 weeks later...
Guest sHoEsTRiNG
Hi Martin!
i tried the broccoli programmer with my 18LF452 pic, all is well and double-checked the finished circuit, when i tried to readcfg, broccoli returned "Unknown device" and all are zero's.
my question is: Do broccoli18 really supports 18LF452 or just 18F452?
i've read your post that you successfully burned an 18LF452 pic, how did you did it?
i made my circuit without modification on LVP mode, i just want to read the device if it will detect my 18LF452.
maybe i'll to cut the Vpp/MCLR to LPT and connect to the +9V battery.
i'll just post here the result.
thanks in advance dear moderator and martin!  :)
Link to comment
Sorry for answering this late...
Check out your Voltages!!!
I strongly recommend using the 9V battery, not the unmodified version. I tried an F version first and immediately modified for the non-LVP version (without trying an LF). And yes, then there is no difference in burning F and LF version of the pic, the LF version will be recognised as 18F452. Be sure to make several tries in a line to "pump that elko up". I have a very fast machine with a stable and TTL compatible parallel port, maybe you have to recompile the source using another delay time, hmmm... make sure to get the right resistor for "your" port voltage! Don't leave out a step in testing before actually putting the pic in. Have you tried an 18F452 as well?? Very surprised, since you said "double checked"- have you verified the pin voltages in the socket??? everything fine? There is not many chance to make make something wrong with this one...(i managed to get a broken solder point at the batteries :P)
Hope you get it soon...
Link to comment
Hi all,
Im very interested in this new PIC programmer, gave up with my JDM and whole project has been on hold ever since! I have the first few idiotic questions, hope they dont drive you too crazy ;)
The message says to not forget to calculate the resistor value, I have checked the voltage put out by my paralell port by using a multimeter and running the broccoli portdiag software. How do I calculate my resistor value?
Just to check because I am not 100 percent sure what Martin means by an "elko" capacitor. The only 0.1uF cap I have is a ceramic disk type, my guess is this should be suitable as the schematic doesnt seem to indicate a polarity for the cap. Is my basic electronics logic correct??
Anyway I look forward to the help and who knows, before 2010 I may have a PIC with the bootloader burnt ;))
Kindest Regards
Dave mK
Link to comment
OK,
i used a rad cap, polarity is + to vdd, - to ground (self explaining). Don't know if ceramic might be a prob, dunno really, cause didn't test it  ;).
Resistor (in Ohm) should be measured Voltage (in V) divided by 0,015 (Ampere). Since resistor value must not be that precise 5-10 % difference shouldn't matter at all.
I felt the same as i began with my project...
"Some day i will have a bootstrap on this chip... maybe tomorrow, maybe next week,... maybe next year..."
Don't give up your hope!
Voltage of the port should be somewhere between 3.3 and 5 V.
I hope this helps.
Let us know if you got it working and don't be afraid to ask again if not!
Don't give up.
Martin
Link to comment
hi
i just finished my JMD and tried to burn the bootloader with little success.
i want to try Broccoli18 BUT:
1) i dont have a good multimeter, i just have a DIY voltmeter (not precise).
2)i dont think i have enough info on this new programer but i belive in its abilities.
3)i do not have access to a local ecectronics store (only by internet), additional costs apply for a small order, but i do have a parallel secket at home.
4)i do not have a regulated PSU.
i do still have my JMD but when i connected external PSU to it ,(because i had 4.5v on MCLR#) it cooked the zener diode.
please help ! Anyone !!
i hope i can finish it by september.
thanks in advance.
Yarek T.
Link to comment
Hi martin,
thanks for the speedy response and encouraging words!
The reason Im double checking about the capacitor is because I have three local suppliers and they all told me that they dont stock electrolytic caps at such low farad values.  The smallest cap I can get without resorting to mail order is a 0.5uF electrolytic.
I think I will try this as a matter of interest and hopefully I wont fry my PC :)
If not I will have to order one from the net.... more info to follow!!
Dave M
Link to comment
Well,
It's a  "power supply bypass" cap.. so you can try a 'bout  any value. IT won't fry you PC.. (parallel port is buffered, anyway)
Bye, Moebius
p.s. Do you have some "electronic junk" -  take it apart and you will find right cap. ;)
Link to comment
Yes, electronic junk is the best u can try to get masses of caps in good quality and unusal values.
I got the one for broccoli "directly from the street" from a hill of junk! If you have no 9V PSU give the batteries a try before you give up, one 9V battery for 10 to 15 pics is not THAT bad if you mainly wanna check out if your burner works.
Link to comment
  • 2 weeks later...
Hi all,
I just wanted to say that after almost 6 months of twiddling with my JDM module without success today I used the simple broccoli programmer to burn the bootstrap! I can whole heartedly endorse this programmer, it is very simple to build on a breadboard and seems a lot less fussy than my JDM.
I would like to thank Martin Haverland and moebius for answering my initial questions and helping me to not be paranoid about blowing up my music computer :)
I just downloaded mios also, it responds correctly to sysex messages so now all I have to work out is how to compile (and a million other things!!) and soon I will be a happy MBSeq owner :))
Hope you all have a nice summer, Im off to the beach!!
Dave Moss
Link to comment
  • 3 weeks later...
hi
thanks for ignoring my post, this is a realy helpfull forum (NOT). i'm getting tired with stuff like that !! you are off to the beach? and i have to stay in the house and tinker with my smoked JMD, with no help from you guys !! i promised my "sponsors" that it will be finished by september !!
P.S. sorry for my attitude, it had to come out, i'm pleased that there is smonething simpler that JMD and i want to try it (as a beta tester) but i cant without any help from you guys.
Link to comment
Strangely enough, I haven't succeed in starting a flame war yet (this is a friendy forum), but this might be it ;)
First of all: Dear Fx3_hdrive, did you check what is the topic of this thread? Is it "yet another failed JDM attempt"?! Or?
Then again. Checked the topic - we are talking 'bout broccoli18 here.. If you need information on that, you might be better off searching for it (try "Latest News"), than moaning things like: "I don't have a precision multimeter, how come I can't succeed in building anything that needs voltages to be measured (and that missin' resistor didn't help either)".. Well, anyway, for that I could say: Go BUY ONE! You need one. Try nearest full service gas station. Probably DVM is cheaper than PIC.
Yes, actually. It's pretty nice to lay down, relax and use laptop with wireless internet to read the forum and post replys to people with problems, who are WILLING TO HELP THEMSELVES..
That's not my commitment, nor anybody elses on this forum but yours. Reminds me for a song by Def Leppard: "I don't want to make promises I can't keep..."
Bye, Moebius
Link to comment
dear hx3_hdrive,
here a few answers...
BUT:
this should NOT be a great problem if it is around 20%something precise IMHO
??? there's a really good website about the original, a schematic, a howto, descriptions, and this is a nearly NO PARTS programmer...i'm sorry, but i don't think there will be much more doc for any no parts programmer on the internet...
as already said: you can get these few parts from nearly any electronic junk pieces, there's really nothing special to it (old radios, vcr, ...), that's how i build it (and this wasn't a monetary problem for me at all...)
first of all...JDM, not JMD...second: have you measured the psu with your voltmeter?
third: is the battery solution too expensive for you?
I don't want to offend you, but IMHO the projects on ucapps belong to the best documented audio/midi diy projects in the web...
broccoli consists of mainly 2 parts (and the pic and a computer). I doubt if there can be more useful information about this programmer as already posted...
no, i was not at the beach but working in shifts and spending every free minute in audio and midi diy and sleep no more than 5 hours a day maximum...
not as tired as me i'll bet...
that's ok for me, i just wanted to make clear that the helping people at this place have lifes, they have to work, to eat and to sleep and they don't get any money from their support for others.
just my thoughts, ok?
Link to comment
hi
I'm sorry for your attitude also.
Looks like you might have just found a way to insure that you don't get any further help.
A few posts like this and the people who post any kind of help will disappear.
I know you are frustrated but don't take it out on us.  Use that energy to find yourself a cheap DMM and learn what you need to know to understand the instructions that have been graciously laid out before you.
Might be time to call your "sponsors" (are you building this commercially or to get a passing grade in school via another persons work?) and tell them that you could not find anybody who thinks DIY means do it for you.
Don't make this a hostile place.
SmashTV
Link to comment
Guest
Reply to this topic...
