Dimitris_FX_freak Posted October 13, 2004 Report Share Posted October 13, 2004 I had this idea when I realised that the Panasonic motorfaders are useless in the LC emulation(not touch sensitive).So i though that instead of the motorfaders to have another 8 encoders that means 17 in total. My querry is firstly are there 8 available spare connectors for the encoders and last does that need changes in the code?Thanx Quote Link to comment Share on other sites More sharing options...
Sephult Posted October 13, 2004 Report Share Posted October 13, 2004 Check under Midibox LC/DesignThere is a .pdf with the connections for encoders. The top picture only shows the (1) dinx4 board. You can hook 4 of them up, so yes you can use 17 encoders. As for programming, you will have to set up your miditables correctly, that I know. There will be a little bit of setup, but nothing should be too complicated. Quote Link to comment Share on other sites More sharing options...
Screaming_Rabbit Posted October 30, 2004 Report Share Posted October 30, 2004 ... ever thought of building something like this with encoder and LED bar underneath the belt?http://www.pennyandgiles.com/docGallery/85.PDFYou could take a crawler of RC tanks for the belt or rubber touth belthttp://www1.ch2.conrad.com/xl/2000_2999/2200/2280/2282/228292_BB_00_FB.EPS.jpgor mold one out of silicone.I once tried (about 10 or 15 years ago) one of those p&g at a music fair... they don't feel too bad... better than rotary encoders.Greets, Roger Quote Link to comment Share on other sites More sharing options...
