MB64e will never ever work, no way
Melonenmonster
Of course I'm just kidding, but please explain:
If you have 16 LEDRINGS with 11 LEDS each, and all are turned on,
then the current flowing into the common cathode pin is, during
each 1/16 time interval, 11*(5v-2v)/220 = 11*14mA = 154 mA.
But the 74HC595 is specified for 25mA input current at any voltage.
Why does it work? Where is my blind spot?
Or is the 25mA number only valid if all pins carry that current at the same time?
Yours,
Melonenmonster
Whats the point of a ledring with all the leds turned on? arent they usually used by turning on one led to show the position? ???
no i think the ledrings we use have all leds on if the value it represents is maximum, no leds on when value is minimum (like a meter)
@melonenmonster; dunno why, but it works of course
cheers, marcel
That's true for the LED side connected through resistors with the Outputs.
But the other pin of the LED is also connected to an Output of the 74HC595.
So, since all pins of the LEDs are connected to the serial register outputs,
if you have a row or a column of LEDs active at the same time means that
in any case a single output must handle multiple active LEDs.
Melonenmonster
hi,
I think you make a valid point. As the cathode driving pin reaches its maximum current sinking of 25mA or thereabouts the voltage on this pin will increase which means less current through each LED.
If this is the case, then the brightness of LEDs in a column will gradually decrease as each additional LED is turned on. It may be not very noticable.
(btw; I think the LED rings can operate in different modes so you can have single dot being displayed if you want.)
two solutions I can think of:
1) use high output LEDs (say 100's of mcd) and increase 220R to 1.5k -> (5-2)/1.5k=2mA per LED
2) put a darlington array such as ULN2003 in front of the column driver. You'd have to invert the DOUT signals to these driver lines in the firmware (not hard to do, I believe).
cheers
Duggle,
you made my day. Not only did you explain what
happens, but also made a very clever proposal.
I thought of some kind of amplification, but that
ULN2003 is really convincing. I didn't do electronics
for many years, so I'm not aware of the current
elements base and would have to search a lot.
I'll setup a test, It'll take some time,
but I'll let you know.
Thank you.
Yours,
Melonennmonster
Another thing to think about is if you connect many LED's, lets say for worst case 128 LEDs. And every LED is drawing approx. 15mA. Then all LEDs (if ON) draw a total of 1,92A !!. Thats a to high current to draw from the core in a tiny flatcable to the DOUT boards. Also the regulator on the core can't deliver this current.  ???
Or is there something I miss here ?
/Wise
