I'm trying to build a MidiboxSid controller in my Clavia G2 - so far so good. But I'm having problems understanding the following from the CC-implementation:
LFO1 Mode
Bit 0: Enable LFO
Bit 1: Sync with assigned note events
Bit 2: Sync with all note events
Bit 6-4: Waveform
           0: Sine
           1: Triangle
           2: Saw
           3: Pulse
           4: Random
           5: reserved
           6: reserved
           7: reserved
Example: 11h = 17 = Enable & Triangle Wave
                  15h = 21 = Enable & Triangle & Sync
I don't understand the "bit 6-4" concept, and I can't seem to figure it out backwards since only Tri waves are mentioned in the example.
It should be stated that I really haven't done much Hex/Bin calculations... ever!  :-\
Any help would be appreciated!
Cheers,
Mikael
Edit: ***PLEASE IGNORE THIS POST***
See below!
And get sleep or you make silly mistakes which can fry your stuff sometimes!!!!!!!
One other way you could read it is this:
LFO1 Mode
Bit 0: Enable LFO
Bit 3: Sine
Bit 4: Triangle
Bit 5: Saw
Bit 6: Pulse
Bit 7: Random
15h  = 10101000 = 21  = Enable & Sync & Triangle
11h  = 10001000 = 17  = Enable & Triangle
other eg:
C2h = 11000010 = 194 = Enable & Sync Assigned & Pulse
1h    = 00000001 = 1 = Disable & Random
I was thinking the other day that it would be really nice if there was an app that had three text boxes, one for binary, one for hex and one for decimal... And if you type a number into any box, it converts the other two boxes as you type... I thought a +/- box would be good too... And bit shifting (left/right)...And an option with the binary to type from right to left like you read it....
Of course, it's very simple to program, I just dont have visual C on this machine... Isn't there an open-source c++ IDE/Compiler on sourceforge?
Anyway there's this: http://www.aquariussoft.com/downloads/pc-binary-conversion-downloaded.asp .... it's nagware though, $14 to buy
There's this freebie, very nice and simple, but no shifting, and rather limited: (also note the LCD character generator there, look familiar? :) ) www.everydaylogic.com
There's some code here:
http://www.marston-home.demon.co.uk/Tony/uniface/tip32.html
And some theory here:
http://www.janeg.ca/scjp/oper/binhex.html
Google is your friend, this is everywhere...
Hope this helps
bit 6-4 means bit 4,5 and 6 together can form a number 0-7 selecting one of the options listed. It is written backward (6-4) because the high value of those three bits need to go into bit 6.
So;
Bit
654
000 Sine  (== 0+0+0 = 0)
001 Triangle (== 0+0+1=1)
010 Saw (== 0+2+0 =2)
011 Pulse(==0+2+1=3)
100 Random (==4+0+0=4)
101 Res ...
110 Res
111 Res
Of course the bits have pos 4, 5 and 6 so the actual values when put into this cc value are 16, 32,64.  (So pulse is 48)
Note that when writing a value bitwise you should (as with all numbers) start with the highest value bit. (Bit 7 in this case)
So 1000 0010 = (128 + 2) = 130.
bit 7654 3210
You can do also sorts of conversions with windows calculator, just put it into scientific mode.
Man I need waaayyyyy more sleep, I can't think straight! This is what happens when you are working 70+ hours a week!  ;D
That is so funny, I went to adjust the post and I even said in there:
Notice C2 was correct, but 1 was not?
LOL!  :D I converted it from 5 bit to 8 bit by tacking the 000 on the *end* for some strange reason hahahahaaaa
*slaps himself*
I didn't even notice it said 6-4, i just assumed it was 3-7 for some fricken weird reason.
Regarding windows calculator, you can do that, but you have to make too many clicks to get a quick answer. There's calculator.org too for that kinda thing.
Anyway, just to clear it up, here it is, correctly this time! (with examples to clear it up for those new to binary, which you'd think I was today!)
XXXXX001 = Enable
XXXXX010 = Sync assigned
XXXXX100 = Sync all
X000XXXX = Sine
X001XXXX = Triangle
X010XXXX = Saw
X011XXXX = Pulse
X100XXXX = Random
00010001 = Enable & Triangle
00010101 = Enable & Sync & Triangle
00010011 = Enable & Sync Assigned & Triangle
00110001 = Enable & Pulse
01000011 = Enable & Sync Assigned & Random
Note bit 3 & 7 (read from the right)never get used
Just to show how tired I am, in this tiny post, I have made over 32 typing errors!!! 6 in this sentence alone! I'm really sorry if I've caused any confusion. If I get it wrong this time, someone pelase shoot me so I get some sleep for a change!
Exactly. Because the highest bit is never used, there are only 7 bits used.
in binary, the most you can you can have is 1111111
The way it works is this...
If the byte is all 0's, that's 0. Thats nice and easy :)
The 1st bit, from the right hand side, is equal to 1 in decimal when it is set, or on, or a '1'. However you like to say it
The 2nd bit, from the right hand side, is equal to 2 in decimal
The 3nd bit, from the right hand side, is equal to 4 in decimal
The 4th bit, from the right hand side, is equal to 8 in decimal
The 5th bit, from the right hand side, is equal to 16 in decimal
The 6th bit, from the right hand side, is equal to 32 in decimal
The 7th bit, from the right hand side, is equal to 64 in decimal
The 8th bit, from the right hand side, is equal to 128 in decimal
So you see, the decimal value doubles each higher bit
You then add up the value of any bits that are 'set' - the one's.
So
00000001 is 1
00000010 is 2
00000100 is 4
10000000 is 128
but in this case we don't use bit 7 -
and
00000101 is like 4 AND 1 (see just above), so that's 5
00000111 is like 4 AND 2 AND 1, so that's 7
00010001 is like 1 AND 16, so that's 17
10000000 is 128
10000001 is 129
10000010 is 130
Maybe this helps...
So anyway, because this is a computer not a human, the counting starts with 0, not with 1.
As you know, we don't use bits 7 or 3. This is counting from 0. So we never use the 8th bit from the right - bit7, or the 4th from the right, bit 3. The far right bit, the "1st" bit, is called bit 0, because we're counting from zero, not one.
so this means that the highest you can go with 7 bits is like this:
01111111
If you grab the calculator of your choice, and convert from binary to decimal, you will find that this is 127 decimal. This allows 128 different settings, including zero.
I hope this helps, and doesn't confuse matters further. I have had alcohol to drink for the first time in years tonight, so this may be completely incomprehensible!
More sake and moet please!!  ;D  ;D
