Linked cores
lukas412
You could just build the 2 different cores/apps. in one box; connecting via midi internally. Then (i think) you can also select midimerger or something in the apps. so they behave as one...but i'm not sure; read the info manuals of the apps you want to build; it's in there somewhere.
good luck, marcel
Yes I did, that led me to this question.  What I want is to build my current controller that I have planned, then eventually add a MBLC to my setup, but I just thought it would be nice to integrate them together via the midibox link. Im just still unsure as to whether you have to write a custom program or if you can just run the established applications in different combinations.
Thanks for the help,
Luke
