Is it possible get the value of the active submenu and then have a corresponding led light up?
I think I can use the "CS_MENU" label for this, but I wrote a (much too) complicated function which grinded my mbsid to a halt. After a restart it kept on updating the patches or something and I had to reload MIOS and a older backup of my software...  So that didn't work very well.  :P
Any code guru's?
Look,
the leds of the right menu buttons need to light up with the corresponding menu.  8)
The buttons and menu navigation already work.
you could control the additional LEDs in cs_menu_leds.inc, example:
CS_MENU_LED_Update
clrf MIOS_PARAMETER1 ; clear LED by default
movf CS_MENU, W
xorlw CS_MENU_OSC
skpnz
setf MIOS_PARAMETER1 ; set LED if CS_MENU == CS_MENU_OSC
movlw 8*(7-1) + 0 ; SR7, pin #0
call MIOS_DOUT_PinSet
[/code]
