Motor Automation question
Guest Rochey
Thorsten,
If I was to use the motor control, and I want to control faders other faders with one fader, is it possible...
for instance,
I move with fader 1, can i get fader 3 and 4 to move up or down at the same time? - and possibly get tracks 3 and 4 to record this automation data?
cheers
R
Hi Rochey,
yes, this will be possible in conjunction with the individual touch sensors for each fader. If your motorfaders don't come with a sensor pin, you can use buttons instead. It's also important that your software supports an automization mechanism (Logic Audio: Read/Touch/Write/... mode)
