CEM3378 Filter: first impressions
TK.
Today I did the first experiments with a CEM3378 filter, which some
of the germans purchased in a collection order from synthtech.com
A top view of the workbench:
Right side: A AOUT_LC module based on the schematics from Karl Dalen.
It mainly consists of 2 * 74HC595 and not less than 36*10k resistors to realize
a 12bit DAC, which controls the Cutoff frequency.
The final version I'm planning will consist of 48*10k resistors for an 12bit DAC
(CutOff) and 4bit DAC (Resonance) (I guess that the resolution is enough, especially
because I have to build 4 of them ;-)
In addition this module has an OP-Amp to control the gain and offset of the
output CV - for the filter it turned out that this is a very important feature
Bottom: the CEM3378 circuit (based on the datasheet) + a +/- 5V voltage regulator.
Both, the filter and the AOUT_LC circuit are powered with this low biased voltage.
In addition, the CEM3378 needs +12V
Left side: ok, my beloved MBSID
And here the first demo - MBSID in TB303 mode, controlled via MIDI (internal
sequencer not used) - filter/envelope parameters tweaked in realtime
http://www.ucapps.de/mp3/midibox_sid/mbsid_demo11.mp3
IMHO the filter sounds very good, especially on filter sweeps it can be noticed
that the volume doesn't get lower even when resonance is close to self-oscillation.
During the first tests I also noticed, that key-tracking is a must for such a filter.
Therefore I implemented it into the firmware (CC#6) - now I have to find a way
to store this value, because the SysEx data structure is completely  allocated :-/
low cost vcf aswell?
It is - $10 + taxes + shipping is a fair price compared to the effort which is required to build a discrete filter
Yes, it's just the TB303 mode - not the typical TB303 sound. In fact I wasn't able yet to realize the same filter behaviour like on my moog-filter yet, I think that I have to optimize the OP stage at the end of the DAC, or the voltage divider at the CEM3378 filter CV input in order to fix this.
However, the filter gave me some enjoyable hours today, it already makes a lot of fun to play with this toy :)
Fx processor: there was a guy who realized a DSP project for such jobs, search for "miss parker" in the forum
On the other hand: I prefer the use of VST plugins. The usage is simple and more flexible.
Eh.. IMHO the application of the 3372 in the polaris is sub-par.  That chip is capable of much more.  I'll have to check the sheets, but I also think there are some differences between the 72 and 78.  The 72 is also what was used for the massive multimode beast in the oberheim Martix-12 and XPander synths, the Xpander manual actually has a full app note about it too, check it out at bluesynths.com.  Quite a nice chip really.  Keep an eye out on ebay for SSM2044's too, those are nice (Mono/Poly, Wave 2, etc;)
I'll have to check the sheets, but I also think there are some differences between the 72 and 78.  The 72 is also what was used for the massive multimode beast in the oberheim Martix-12 and XPander synths...
There are some differences, but it doesn't prevent using CEM3378 in similar multimode configuration as
3372.. all the gain cells have output taps.
Keep ya hands off of SSM2044s.. I might need some for my Polysix.. :D
Bye, Moebius
Hi Marcel,
link to the layout: http://www.ucapps.de/mbhp/mbhp_aout_lc_v1.brd
link to orderlist: http://www.ucapps.de/mbhp/mbhp_aout_lc_orderlist.txt
Yes, the SHX8 board can be used, but there is currently not firmware which supports this combination. And I'm sure that it won't be possible with MBSID or MBFM, but it will be supported by MB64 and MBCV (sooner or later...)
