documentation discrepancies
gm02froe
Hi
I found the following discrepancy in the documentation for the core:
http://www.ucapps.de/mbhp_core.html
it states under available ports J2:
....In both cases the voltage regulator (IC2) should not be connected, also the rest of the voltage stabilization circuit between J1 and J2 (X1, C5, C6) can be left out...
according to this diagram:
http://www.ucapps.de/mbhp/mbhp_core.pdf
IC2 is the optocupler.
same thing further down under "used components".
I assume the labeling in the core diagram is wrong, right?
I am a newbee in electronics and just want to be sure, cause I want to power my two cores with 5V supplies.
best regards
martin
