Theory? Posted September 1, 2006 Report Share Posted September 1, 2006 I want to build a dedicated knob-per-function controller for my Waldorf MicroQ. I figure it should be a 64e, but with certain functions like my osc. shape and octave I don't need the vast range of normal encoders. Does anyone know of any encoders that have a shorter range? I doubt such a thing exists detented, but you never know.Also, the MF module can be integrated into a 64e right? Quote Link to comment Share on other sites More sharing options...
stryd_one Posted September 2, 2006 Report Share Posted September 2, 2006 I'm very interested in this project :)What do you mean by "range" on encoders? Are you thinking of pots perhaps? Encoders have an infinite range (like the mq, they just go round and round). Pots usually have a range of 270o, if you have an analog mixer you will know what I mean. Hopefully this link will help. I would definitely use encoders, you want to be able to make the thing sit in the rack next to your mq and so it would make sense to use the same kind of control. Do you know how many knobs you want yet?For stuff like selecting oscillator waveforms, I'd just use a single button which scrolls through and enough LEDs to show which is selected. Take a look at the MBSID to see what I mean. Quote Link to comment Share on other sites More sharing options...
TK. Posted September 3, 2006 Report Share Posted September 3, 2006 For most CCs you can just reduce the range of the sent values - this can either be done with Serge's Editor or (the method I prefer) with the mk_syx scriptE.g., for the LFO1 Shape (CC15), you have to define the range 0..5Only the "OSCx Octave" (CC#27, CC#35, CC#42) needs a special handling, since the CC goes from 0..127, but only the values 16, 28, 40, ... 112 are doing a change. For this you have to reduce the value range to 0..7, and the Meta handler has to send a CC based on this formula: 16 + (n*8 )Best Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
stryd_one Posted September 4, 2006 Report Share Posted September 4, 2006 Oh yeh that reminds me - TK uses a MicroQ, we should ask him ;) Quote Link to comment Share on other sites More sharing options...
Theory? Posted September 7, 2006 Author Report Share Posted September 7, 2006 For most CCs you can just reduce the range of the sent values - this can either be done with Serge's Editor or (the method I prefer) with the mk_syx scriptE.g., for the LFO1 Shape (CC15), you have to define the range 0..5Only the "OSCx Octave" (CC#27, CC#35, CC#42) needs a special handling, since the CC goes from 0..127, but only the values 16, 28, 40, ... 112 are doing a change. For this you have to reduce the value range to 0..7, and the Meta handler has to send a CC based on this formula: 16 + (n*8 )Best Regards, Thorsten.Awesome. Thanks so much.If I want to use a button for the OSC, do I just modify the script to say that each toggle represents so-and-so value? Quote Link to comment Share on other sites More sharing options...
TK. Posted September 7, 2006 Report Share Posted September 7, 2006 In this case you also need a meta event which cycles between the valuesBest Regards, Thorsten. Quote Link to comment Share on other sites More sharing options...
dinama Posted May 22, 2012 Report Share Posted May 22, 2012 I'm very interested to the solution. I have the same problem for controlling the waveform selector in a minimax plug-in (plugiator) Controller n° 79 (HEX VALUE 4F) Permitted values: 0-22-44-66-88-110 or in hex value 00-16-2C-42-58-6E Maybe it is possible to use a rotary switch connected to digital input of DIN. Quote Link to comment Share on other sites More sharing options...
