SID problem....
Stigmata
Hi Christoffer,
under http://www.ucapps.de/mbhp_prg.html you will find a test program for the SID module which starts with a chort at power-on. On this way you can ensure that the Core module can access the SID and that the Audio Out is working. Thereafter you can use the same program to test the MIDI-In (a saw sound should be played on Note events). If this works, you can continue with the original MIDIbox SID firmware
