Component questions (different pakages)
jensah
I've started to build a FM module, but i got smd tl074 and a "standard 2 pin" 14.318Mhz crystal.
Have anyone made a circuitboard for thoose components?
The SMD tl074 would work, but you have to make yourself a pcb for it, I think.
For the crystal I am not so sure. There are some differences between the crystal-types, so I'm not sure, If yours will work.
In theory you could use two (DC-) wallwarts to get +/-12V. Not a recommend solution, but it would work.
greets
Doc
This page here describes how to build a +/- power supply from a AC-AC wallwart.
http://electro-music.com/forum/topic-12968.html
I think this is the kind of wallwart he recommends to use.
http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=100061&pa=100061PS
Would someone else like to double check this and make sure it would work?
