Pad bank control question
and15
I am still in the design process for my midibox and i have purchased a set of 16 of the monome pads and would like to use these 16 pads to control 32 of the digital in's. i want to set it up similar to a bank control found on most samplers.  I am not sure how to achive this would i use an analog multiplexer to select between the two inputs to the one switch or is there some type of multiple relay that is available.    Any tips would help.
-Andie
Would be easier (IMO) to write the a custom app in C.
You could do this by creating a table of midi events. 32 entries long.
With a bank switch button you can toggle the bank.
and then use something like "pin * bank = entry"
finally send the midi info in that entry
Happy to help you out
hi
why don t you keep the 16 pads connected to the same DIN inputs and use the bank switch function? I don t really understand why you want to phisically map the 16 buttons to 32 inputs.Banks are already implemented in MB64(E), you only need one o more buttons to dedicate to the bank switch.. that s it
simone
