I've built a AOUT LC, activated it in the SW, but I only get 0 to +/-5V out.
I'm using a +/-15V PSU (Old MOTM PSU)
Resistor values are OK...
I didn't bother to match the 10K resistors for this one.
And now that I'm asking questions, my MIDI out ports 1 & 2 give the same output. I mean, when selecting midi out 1, I also see the led of midi out 2 blinking. Midi out 2 is "available". I must admit I didn't install the 1K (or was it 10k) resistors connected to 5V at the selection pins.
Any ideas?
Cheers,
Tom
Hi Tom,
which voltage do you measure on the positive inputs of the OP amp, is it between 0V and 5V (depending on note or CC value?)
IIC modules: the resistors are required so long the pins are not directly tied to Vs or Vd in order to ensure a stable logic level. Otherwise random things can happen (like you've probably noticed)
