brother303 Posted October 10, 2007 Report Share Posted October 10, 2007 Hi to all,just started building a mbfm. I want to put it into the same pactec-case as the mb6582 with a frontpanel from Schäffer.Now I want to know if it`s possible to run the fm with a 4x20 display instead of a 2x40. Any drivers required? Or change something in the asm?Thanks lot! ;DGreetzBrother303 Quote Link to comment Share on other sites More sharing options...
stryd_one Posted October 10, 2007 Report Share Posted October 10, 2007 It'll scroll off onto your bottom row.http://home.iae.nl/users/pouweha/lcd/lcd0.shtml#_2_line_displaysYou might want to do a search, I'm sure this has been done before. Quote Link to comment Share on other sites More sharing options...
Wilba Posted October 10, 2007 Report Share Posted October 10, 2007 just started building a mbfm. I want to put it into the same pactec-case as the mb6582 with a frontpanel from Schäffer.I plan to do the same, but I'll probably stay with a 2x40 display for convenience.Use of 4x20 display has been done before:http://www.midibox.org/forum/index.php?topic=7545.0No change to firmware required, but as mentioned in the thread, it's not perfect.Just look at the manual, you'll see how the main screen will get split in the middle of the patch name.http://www.ucapps.de/midibox_fm_manual.htmlWith a little bit of coding, you could make it look better. Quote Link to comment Share on other sites More sharing options...
brother303 Posted October 11, 2007 Author Report Share Posted October 11, 2007 Hi Stryd,hi Wilba,thanks for the information,think it`ll help!Cool! ;DGreetzBrother303 Quote Link to comment Share on other sites More sharing options...
