Hi all !
I've got a problem with my Core/SID ... the audio out only delivers a big noise !
I did the testtone test and it works fine : no noise, just the square wave - Voltage are ok too.
Also, I have a spare core module. I did a test with it and it works fine (no noise, only good sound  ;) ). This made me thinking that the problem is on the CORE module and not on the SID module.
I double checked, and double checked , and double checked .... the core looks good ... I'm lost !
PS : I'm running SID V1 not V2 with mios 1.9f
PS 2 : I haven't done the Core.SID interconnection test ... I will do it right now but I was wondering if I should keep the SID chip stuffed ?
no PS 3 : too expensive ;)
Thanks for your help !!
