Defines |
#define | J5_NUM_PINS 0 |
#define | J10_NUM_PINS 0 |
#define | J28_NUM_PINS 0 |
#define | J15_AVAILABLE 0 |
Functions |
s32 | MIOS32_BOARD_Init (u32 mode) |
s32 | MIOS32_BOARD_LED_Init (u32 leds) |
s32 | MIOS32_BOARD_LED_Set (u32 leds, u32 value) |
u32 | MIOS32_BOARD_LED_Get (void) |
s32 | MIOS32_BOARD_J5_PinInit (u8 pin, mios32_board_pin_mode_t mode) |
s32 | MIOS32_BOARD_J5_Set (u16 value) |
s32 | MIOS32_BOARD_J5_PinSet (u8 pin, u8 value) |
s32 | MIOS32_BOARD_J5_Get (void) |
s32 | MIOS32_BOARD_J5_PinGet (u8 pin) |
s32 | MIOS32_BOARD_J10_PinInit (u8 pin, mios32_board_pin_mode_t mode) |
s32 | MIOS32_BOARD_J10_Set (u16 value) |
s32 | MIOS32_BOARD_J10_PinSet (u8 pin, u8 value) |
s32 | MIOS32_BOARD_J10_Get (void) |
s32 | MIOS32_BOARD_J10_PinGet (u8 pin) |
s32 | MIOS32_BOARD_J10A_Get (void) |
s32 | MIOS32_BOARD_J10A_Set (u8 value) |
s32 | MIOS32_BOARD_J10B_Get (void) |
s32 | MIOS32_BOARD_J10B_Set (u8 value) |
s32 | MIOS32_BOARD_J28_PinInit (u8 pin, mios32_board_pin_mode_t mode) |
s32 | MIOS32_BOARD_J28_Set (u16 value) |
s32 | MIOS32_BOARD_J28_PinSet (u8 pin, u8 value) |
s32 | MIOS32_BOARD_J28_Get (void) |
s32 | MIOS32_BOARD_J28_PinGet (u8 pin) |
s32 | MIOS32_BOARD_J15_PortInit (u32 mode) |
s32 | MIOS32_BOARD_J15_DataSet (u8 data) |
s32 | MIOS32_BOARD_J15_SerDataShift (u8 data) |
s32 | MIOS32_BOARD_J15_RS_Set (u8 rs) |
s32 | MIOS32_BOARD_J15_RW_Set (u8 rw) |
s32 | MIOS32_BOARD_J15_E_Set (u8 lcd, u8 e) |
s32 | MIOS32_BOARD_J15_GetD7In (void) |
s32 | MIOS32_BOARD_J15_D7InPullUpEnable (u8 enable) |
s32 | MIOS32_BOARD_J15_PollUnbusy (u8 lcd, u32 time_out) |
s32 | MIOS32_BOARD_DAC_PinInit (u8 chn, u8 enable) |
s32 | MIOS32_BOARD_DAC_PinSet (u8 chn, u16 value) |
