mios32/STM32F4xx/mios32_usb.c File Reference
#include <mios32.h>
#include <usbd_core.h>
#include <usbd_def.h>
#include <usbd_desc.h>
#include <usbd_req.h>
#include <usbd_conf.h>
#include <usbh_core.h>
#include <usbh_conf.h>
#include <usb_otg.h>
#include <usb_dcd_int.h>
#include <usb_hcd_int.h>
#include <usb_regs.h>
#include <string.h>
Defines
#define DSCR_DEVICE   1
#define DSCR_CONFIG   2
#define DSCR_STRING   3
#define DSCR_INTRFC   4
#define DSCR_ENDPNT   5
#define CS_INTERFACE   0x24
#define CS_ENDPOINT   0x25
#define MIOS32_USB_MIDI_NUM_INTERFACES   2
#define MIOS32_USB_MIDI_AC_INTERFACE_IX   0x00
#define MIOS32_USB_MIDI_AS_INTERFACE_IX   0x01
#define MIOS32_USB_MIDI_INTERFACE_OFFSET   2
#define MIOS32_USB_MIDI_SIZ_CLASS_DESC   (7+MIOS32_USB_MIDI_NUM_PORTS*(6+6+9+9)+9+(4+MIOS32_USB_MIDI_NUM_PORTS)+9+(4+MIOS32_USB_MIDI_NUM_PORTS))
#define MIOS32_USB_MIDI_SIZ_CONFIG_DESC   (9+MIOS32_USB_MIDI_USE_AC_INTERFACE*(9+9)+MIOS32_USB_MIDI_SIZ_CLASS_DESC)
#define MIOS32_USB_MIDI_SIZ_CLASS_DESC_SINGLE_USB   (7+1*(6+6+9+9)+9+(4+1)+9+(4+1))
#define MIOS32_USB_MIDI_SIZ_CONFIG_DESC_SINGLE_USB   (9+MIOS32_USB_MIDI_USE_AC_INTERFACE*(9+9)+MIOS32_USB_MIDI_SIZ_CLASS_DESC)
#define MIOS32_USB_COM_NUM_INTERFACES   2
#define MIOS32_USB_COM_SIZ_CONFIG_DESC   58
#define MIOS32_USB_COM_CC_INTERFACE_IX   (MIOS32_USB_MIDI_INTERFACE_OFFSET + 0x00)
#define MIOS32_USB_COM_CD_INTERFACE_IX   (MIOS32_USB_MIDI_INTERFACE_OFFSET + 0x01)
#define MIOS32_USB_COM_INTERFACE_OFFSET   (MIOS32_USB_MIDI_INTERFACE_OFFSET + 2)
#define MIOS32_USB_NUM_INTERFACES   (MIOS32_USB_MIDI_NUM_INTERFACES + MIOS32_USB_COM_NUM_INTERFACES)
#define MIOS32_USB_SIZ_CONFIG_DESC   (9 + MIOS32_USB_MIDI_SIZ_CONFIG_DESC + MIOS32_USB_COM_SIZ_CONFIG_DESC)
#define MIOS32_USB_SIZ_CONFIG_DESC_SINGLE_USB   (9 + MIOS32_USB_MIDI_SIZ_CONFIG_DESC_SINGLE_USB)
#define MIOS32_USB_SIZ_DEVICE_DESC   18
Functions
void USB_OTG_BSP_Init (USB_OTG_CORE_HANDLE *pdev)
 USB_OTG_BSP_Init Initilizes BSP configurations.
void USB_OTG_BSP_EnableInterrupt (USB_OTG_CORE_HANDLE *pdev)
 USB_OTG_BSP_EnableInterrupt Enabele USB Global interrupt.
void OTG_FS_IRQHandler (void)
 This function handles OTG_FS Handler.
void USB_OTG_BSP_uDelay (const uint32_t usec)
 USB_OTG_BSP_uDelay This function provides delay time in micro sec.
void USB_OTG_BSP_mDelay (const uint32_t msec)
 USB_OTG_BSP_mDelay This function provides delay time in milli sec.
void USB_OTG_BSP_ConfigVBUS (USB_OTG_CORE_HANDLE *pdev)
 USB_OTG_BSP_ConfigVBUS Configures the IO for the Vbus and OverCurrent.
void USB_OTG_BSP_DriveVBUS (USB_OTG_CORE_HANDLE *pdev, uint8_t state)
 BSP_Drive_VBUS Drives the Vbus signal through IO.
s32 MIOS32_USB_Init (u32 mode)
s32 MIOS32_USB_IsInitialized (void)
s32 MIOS32_USB_ForceSingleUSB (void)
s32 MIOS32_USB_ForceDeviceMode (void)
Variables
__ALIGN_BEGIN
USB_OTG_CORE_HANDLE
USB_OTG_dev
__ALIGN_END
uint32_t USB_rx_buffer [MIOS32_USB_MIDI_DATA_OUT_SIZE/4]
const USBH_Class_cb_TypeDef MIOS32_MIDI_USBH_Callbacks
