178 -
Everything posted by Stigmata
No Its not the 8580 chip.. ;) I just tried to change the two SIDs between the core and the sid pcb ,got same problem..... Christoffer
Seems like my question get lost about the JDM! ;) So again: When I burn the PIC its never works at the first time but its allways works at the second time... ??? Just want to know why.. Take care! Christoffer
Seems like one of my SIDs working just perfect (6581)and one of them (the one thats hot)dont works with the cutoff filters, got the same sound)....... ??? Christoffer
My Dc transformer get like 16,50 V= and I supply the SID and the core. Is that wrong? Discover that its works just fine but after a while the SID start to hang up, and dont response at all! Hmmmmm!!Somethings wrong I suppose.. :-/ :( Christoffer
Just discovery that my SID 6581 get very hot, is that normal? ??? Take care! Christoffer
Provade jag också... Vad skrev du?? Själv har jag ju inte nått företag. ;) Vi får se hur det går.Vore ju inte fel att få dessa hem men hoppas man inte binder upp sig för något.. ;D Ta hand om er! Christoffer
Hi! Im not sure but I think you have the same MIDI channel on both SIDs so they respond at the same time and simply pan them left and right, I dont think they can have this flanger type of sound (when the sounds goes from left to right)..... ??? I have them in mono, I simply put my DigiTech TSR-12 multi effect on the mono signal and there I got the cooool sounds in stereo. ;) Take care! Christoffer
Hi there! Just report that my 2 new SIDs working just fine! ;D So now I have two 6581 and one 8580 linking together with one MIDI interface! ;D I like to thank Thorsten for this lovely projects!!!!! Thanks! Take care! Christoffer
Hi there! Got a small problem with the JDM. When I should burn the PIC16F877 it fails the first time, but when I tried the second time it worked just fine.... ??? (Same with both of my PICs...) Not a big problem but I just want to know why. Christoffer
Ok I will try that. Is the Extended MIDI In and the MIDI thru on the outerpins an common thing on all MIDI interfaces? The picture on your SIDs you have only the 15V input. Isnt 15V too much for the CORE? Or did you hide the 7V on the back?? ;) Christoffer
Tror det jag med... Jag har borrmaskiner osv men bara korten kostar ju så där en 50-100 kr för en platta på 100*120 så jag ger upp det där har just beställt från mike istället.... Christoffer PS Hur går det med byggandet?? Själv är jag klar med Min M64 och SID.. Ska bygga två SIDar till ;D Fick just 2st C64..... ;D ;D
Hmmm. Think I understand...... If I connect the MI serial to the MI on the second I disconnect the optocoupler on the second (and the third)CORE? How did you (Thorsten)connect the stereo SID? Think I have to try.. ;).. Christoffer
Vet någon här om det finns press-and-peel I Sverige... (Där man skriver ut på laser och stryker på kretskortet.) Ska beställa lite PCB från Mike men undrar om det är billigare att göra själv??? Elfa är ju så jävla dyra!! MVH Christoffer
New question about the SID.. If I want an MIDI led, can I connect the LTC to the CORE? Going to order the PCB soon... Thanks Christoffer
Yeah! I got two 6581 today for free.!! ;D I hope they work. Christoffer
Found that the IC-prog ver 1.05 supports the PIC18F452... Do you think the JDM works now??? ??? Christoffer
Hi there! Hopefully I got 2 C64 tomorrow.(Hope its the 6581!) ;D. I already got 1 with the 8580.working fine!!!!! My first question to Thorsten: It is worth waiting for the Pic 18F and then build it?? Dont want to order The pic 16f877 if the 18F system is on this side of the year.. ;D Has anyone found an pic burner for the Pic18F ??? Dont want to buy the Picstarter kit (too expensive!) My second question: How can I connect them together? as one synth with diffrent Midi channel. Can I add an ltc module and get the Midi through, and then connect them in serial (MIDI) on the same Midi interface?? Peace! Christoffer
I Get the computer MIDI OUT to M64 MIDI IN and the OUT to the SID working fine but not the M64 must I have an Merger or Independent MIDI interface for the SID?? Seems like the SID not sending MIDI info from the M64. Peace! Christoffer
Working for me here in Stockholm, Sweden!!.. :)
You are the MAN!!! ;D Christoffer
Hi there!! Just playing around with my SID its sooooo cooool!! ;D Just a few questions about the logic env. Im not into Hex or Bit.. For example the waveform parameters you got 8 zeroes. if i turn it to: 00000001 is that the same as Bit 0:Triangle and if i got 00000010 is that bit 1:saw ?? The example in the txt file you got an example 05h = 5 = triangle & pulse how i turn that into logic env.?? Thanks! Christoffer
Thanks a lot! ;D Christoffer
Hi there! Just finished my M64, now Im back to the life again!! ;D Just a few questions: 1:I got 20 button (exept the menu button) only 16 of the working(sending midi and so on) 2:When I got that thing can I assign the leds to it?? 3:Does any one know how to send midi event from Logic 5.2 softsynth like es2 and so on... 4:Ok, if I cant do that how can I get the midi number from all the events?? Thanks! Christoffer
Hmmm! Solved one problem! Seems like bad soldering on the AINX4, the J6 wasnt OK!!! ;D But I still got problem with the second AINX and the rest of the 32 pots! Think I have to use the J7 for the power.. Right?? Christoffer
just did the test prog for the ainx * 2 and its seems like some pots dont work at all an some switch between 2-4 diffrent pot numbers like 56-60 for an example.... :-[ Christoffer
