bosone
    393
Everything posted by bosone
  1. the SID enclosure is a problem also for me... but before finding something in which putting the circuit i have to let it work! ;D anyway, if someone find somethi9ng, let us know... spending 40 euro for th smallest rack unit is a theft!
  2. i have just terminated my CORE module for my SID project. i will do the test in the following days, because i lack the connector for the power supply,. so there is time for some questions! :-) 1) is there any kind of test i can do (apart the voltage control) in order to be sure that the core works, after PIC programming and PC MIDI connection? (some sort of sysex/MIDI communication with MIDI-OX for example...) 2) i have used a TL05 voltage regulator without heatsink... is it safe?? 3) i will not mount the LCD screen. will i have to connect the two trimmers P1 and P2? should i connect a resistor or leave the contacts open?? 4) all the connectors not used in the SID configurations should be leaved open, right? :-) 5) i have a power supply at 16V 800-900mA (don't remember...) is it OK for powering both module?? thank you very much!! matteo
  3. 13 SIDs??!! well, if mine will not work i'll request one from you!!! i'm about to begin my SIDbox project in a few weeks!
  4. can someone provide me the link for the "java package" i supposed to download for using the jsynth??
  5. i had no problems with my current midibox 16 firmware... if i upgrade to next version i have to change the hardware connections like you said, i suppose?
  6. i too am about to build my sid synth! i will use 1 core and 1 sid module and will control everything with my PC thru CC. (no LCD, no banckstic, no knobs...) i have a quesition about power supply: which kind of adaptor should i buy (V out and ampere)? is it correct to use the same adaptor for sid and core? i was reading that sid will heat a lot during operation, i will mount a cooler on it (copper cooler or whatever i found, like the one are found on the video card) and a small fan in the rack.
  7. after midibox 16 (which i build 1yeard and a half ago), i plan to build the SID synth. anyone did this before? any suggestion? thanks!
  8. is there a way to send a sysex to the midibox plus to enable/disable the snap mode, parallax mode, etc?? it not, will you implement it for new firmware release, thorsten? (PLEEEASE!! :))
  9. io ho costruito quasi un anno fa la midibox 16. ci ho aggiunto un pedale di espressione e un breath controller... mi tro vi poco su questo forum,però! ;-) ciao!
  10. I would like to thank thank thorsten for this new great forum! really good work!! matteo
