taximan
    211
Everything posted by taximan
  1. Jeez,,,,,,enuff knobs to start a knoberry.
  2. What be that I wonder? TPD in search box = no results found hmmmmm cheers Paul
  3. Hiya, This is the one I was looking at but the table is too small,apparently bigger machines are in the pipeline though. http://www.mydiycnc.com/catalog/3 cheers Paul
  4. I was going to order a kit from America at a cost of around $500 how does this compare with your costs? Looking good by the way. cheers Paul edit ...I just noticed you are in leeds..................better make sure it's locked up safe at night as I am in Sheffield :)....joking
  5. Hiya, I experienced the same kind of thing with my mbfm build,it turned out I had loaded the wrong type of firmware (I needed to use tks' setting as oposed to the normal firmware). It does sound like exactly the same kind of thing . cheers Paul
  6. Hiya Wilba, I am on the order list for 1 seqv4 pcb and parts kit..............I would like to cancel the pcb order as I bought two from the store and order two parts kits instead. I went to alter the order page but a little voice in my head told me I was gonna screw the order page up..........so for once I listened. cheers Paul
  7. Have you tried adjusting the lcd contrast pot?................................just a shot in the dark
  8. Are you using the lpc expresso software from the guys that make the chip? cheers Paul
  9. Just my ten bobs worth, I have been on the list quite a while (taximan),while I have been on the list I have made other projects and have been looking at making or buying my own seqv4. Or to put it this way,even if I was to make or buy a seqv4 from elsewhere I would still honour my position on the list..........I see it as a verbal commitment to buy. The important thing as I see it is that no one is poached from tims waiting list as that is unethical. Any how too much shit going on in the world without people in here getting into fights...............kiss and make up for fux sake :) cheers Paul
  10. Excellent track guys.......just the kind of sounds I would like to be producing............eventually,well maybe...perhaps. cheers Paul
  11. I am in total agreement with you,kraftwerk for example make great tunes but there concerts are boring.......just 4 guys pushing buttons. A live band playing real instruments can put expression into things and interact with the audience........much better concerts to attend. Or............are we all just getting old? cheers Paul
  12. Hiya, Can't you take the plug from the broken one and use it with the new custom made psu? Just a thought. cheers Paul
  13. Thanks a lot TK, I will order 1xdout board and 1xdin board plus an encoder from smash later. I think I will be using the kingbright 13mm x 8mm (from rapid) displays as used in the gorf sequencer. cheers Paul
  14. Hiya, Just a couple of questions regarding the bpm encoder and digits for the seqv4l.......... Is a 'standard' encoder as supplied by smashtv okay? What do I need to obtain for the digits?............3x single units or a three in one unit?....common anode/cathode etc etc. Does anyone have the physical size of the bpm display digits?.......I could do with the sizes to cut out my case. Over at ucapps it says 2xdout and 1xdin,is this actually referring to the number of the chips? cheers Paul
  15. Hiya, That is one great tune,congratulations. cheers Paul
  16. Hiya, Just a shot in the dark.......on the lowest three tactile switches,the right ones' diode is supposed to be the opposite way round to all the others...........nearly caught me out when I built mine. I also had issues with the mainboard to csboard connections.....might be worth checking again? cheers Paul
  17. @TK The dim led problem is not a dim led problem it is a dim builder problem . Because of the way I have mounted the leds the light shines from the side of the led up the acrylic shaft.....like below I am going to alter it so that the tip of the led transmits the light up the shaft and hopefully it will work a lot better (brighter). I am going to change the 5mm rod for 8mm which allows a bigger slot to be machined into the rod for the led. cheers Paul
  18. Firstly,please excuse my ignorance :) Would it be possible to run this under android? The reason I ask is on ebay there are some cheapo touchscreens going for around £80gbp,now I know they are not up to ipad standards but I am having to pull in the reins on my spending a bit. So,can anyone tell me what would need to be done to run this on android or is it a total none starter? cheers................oh yeah,happy new year as well (in a few hours) Paul
  19. Nice track..liked it up on ytube :) cheers Paul
  20. Hi TK, Which resistors should I change to get the green leds brighter? I need to do this as my leds' are coming through a solid piece of acrylic rod i am using as buttons and they (leds) are a little too soft as it is. cheers Paul
  21. Hiya, I have been looking through my stuff and found 2 supplies that work okay with the sammichSID,one is an ac/ac 12volt 1000ma from ebay and the other one is off my rm1x...ac/ac 12v,1.5amp. Only thing I can say about the cheapo power supplies is check the voltage it's giving out before you plug anything in. hope this helps cheers Paul
  22. Hiya, I just buy suitably rated wallwarts and then fit them with screw type jacks (cut the original off and fit the new one with correct polarity and size 2.1/2.5 whatever.) Got my connectors from here http://www.ebay.co.uk/itm/5PCS-5-5x2-1mm-Female-DC-AC-Power-Plug-Connector-Adapter-Survey-CCTV-Camera-/280765164985?pt=LH_DefaultDomain_0&hash=item415ee86db9#ht_2791wt_952 cheers Paul
  23. Hiya, @ kid versus chemical, No worries mate,it's just that I could see you doing what I used to do and getting frustrated for ya :) The number of times I have said 'oh f**k it' and started over again are unbelievable,all due to getting lost in the mayhem of unguided fault finding. Quoting Nils "Hehe, no I am not specifically grumpy with you, just in general".............Nils speaks the truth....lol. cheers Paul
  24. Hiya, Stop trying to fix things here there and everywhere and follow the advice given by nils....................he's a grumpy german (wack) but he is also very smart and will work through this with you.......if you listen to him. Electronic problem solving needs a methodical step by step approach so that you can ring the changes. (no offence to anyone intended.....................honest) cheers Paul
  25. Hiya, Yaaayyyyy just ordered it........should go nice with all the other stuff I am accumulating...I might even make some music one day...lol. cheers Paul
