addon buttons with my mb808 seq
i´m currently building a new seqboard for my mb808...on my testboard i added few more buttons on for copy/paste/clear track and copy/paste/clear steps...so it´s six more buttons...
in the setup_808_default.asm i call the functions with:
    DIN_ENTRY    CS_M_UTILS_CopyTrack,     2,    3
    DIN_ENTRY    CS_M_UTILS_PasteTrack,    2,    4
    DIN_ENTRY    CS_M_UTILS_ClearTrack,    2,    1
    DIN_ENTRY    CS_M_UTILS_CopySteps,     1,    5
    DIN_ENTRY    CS_M_UTILS_PasteSteps,    1,    6
    DIN_ENTRY    CS_M_UTILS_ClearSteps,    1,    7
...so i does work somehow...although the copy/paste/clear steps is not working as i thought it would be...
copy/paste/clear track is working fine, while the machine runs i can copy tracks...but copy/paste/clear steps is only working when i stop the machine...is there another way to call the function so that it will also work when it´s running?
but better would be, instead of adding six buttons, to have only 3 buttons more with a shift function...so while holding
shift it copies steps and without shift it´s copying tracks...is that possible somehow?
it cannot work properly this way, dedicated button handling functions have to be created.
this would also allow to consider the shift button.
if the examples under seq_buttons.inc don't help, you have to wait until i'm back from vagation.
best regards, thorsten.
so...what i did now is putting this code in the seq_buttons.inc ...or its more a "copy some lines and paste them elsewhere" ...cause its really hard for me to understand asm, as i didn´t do anything before like coding and such things...so its pretty a learning by trial an error... ;)
so here is what i did:
SEQ_BUTTON_COPYTRACK
    call    CS_M_HLP_GetSelectedTrk
    movff    WREG, SEQ_EVNTT
    call    CS_M_UTILS_CopyTrack
    rgoto    SEQ_BUTTON_CPC_Cont
SEQ_BUTTON_PASTETRACK
    call    CS_M_UTILS_PasteTrack
SEQ_BUTTON_CLEARTRACK
    call    CS_M_UTILS_ClearTrack
SEQ_BUTTON_COPYSTEPS
    call    CS_M_UTILS_CopySteps
SEQ_BUTTON_PASTESTEPS
    call    CS_M_UTILS_PasteSteps
SEQ_BUTTON_CLEARSTEPS
    call    CS_M_UTILS_ClearSteps
SEQ_BUTTON_CPC_Cont
    call    CS_M_UTILS_UpdateGPLEDs
    bsf    CS_STAT, CS_STAT_DISPLAY_UPDATE_REQ
    return
SEQ_BUTTON_F4
    SET_BSR    SEQ_BASE
    BRA_IFSET SEQ_MODE1, SEQ_MODE1_SHIFT, BANKED, SEQ_BUTTON_COPYTRACK
    ;; do nothing when button has been released
    btfsc    MIOS_PARAMETER2, 0
    return
    goto SEQ_BUTTON_COPYSTEPS
    return
SEQ_BUTTON_F5
    SET_BSR    SEQ_BASE
    ;; if shift button pressed: start/stop record mode
    BRA_IFSET SEQ_MODE1, SEQ_MODE1_SHIFT, BANKED, SEQ_BUTTON_PASTETRACK
    return
    goto SEQ_BUTTON_PASTESTEPS
    return
SEQ_BUTTON_F6
    SET_BSR    SEQ_BASE
    BRA_IFSET SEQ_MODE1, SEQ_MODE1_SHIFT, BANKED, SEQ_BUTTON_CLEARTRACK
    return
    goto SEQ_BUTTON_CLEARSTEPS
    return
for now its works while running also with the shift function...yippie...but the only limitation is, the stepcopy just works in one part like only A or only in B...but cannont copy steps from A to B as it seems to clear the buffer when changing to another part...puh...will be a next hard night fiddling around...but it starts to make fun somehow...hehe
otherwise i have to wait ´till you´re back from holiday and have some sparetime left. ;)
anyway...wishing you a nice vacation, thorsten
