sparx Posted January 4, 2012 Posted January 4, 2012 Hello all Been trying to get the MIDIO128 V3 playing some MIDI files and I get this appearing in the MIOS Stdio window: [ 713.456] Can't allocate 171 blocks at 850 I've also had some problems with the Sample player so am thinking it might be the SD card Im using which is: 2GB Sandisk with a speed rating of 2, formatted to FAT16. What cards have people used with success? Thanks S
TK. Posted January 4, 2012 Posted January 4, 2012 Hi, [ 713.456] Can't allocate 171 blocks at 850 This message means, that your MIDI file contains a huge meta data block which is larger than the available RAM. It could be a SysEx block for example. Too large blocks will be ignored, and the message will be output as a warning. Best Regards, Thorsten.
sparx Posted January 4, 2012 Author Posted January 4, 2012 Hi Thanks for the reply, no MIDI file seems to work, even one which is 17K in size. Same files on the same card work in the midi player tutorial.
TK. Posted January 5, 2012 Posted January 5, 2012 Could you please send me some of your MIDI files? Best Regards, Thorsten.
sparx Posted January 5, 2012 Author Posted January 5, 2012 Certainly, files sent via email. Thanks and regards Sparx
TK. Posted January 5, 2012 Posted January 5, 2012 Got them, will check tomorrow! :) Best Regards, Thorsten.
TK. Posted January 7, 2012 Posted January 7, 2012 This issue has been fixed in MIDIO128 V3.005 I also noticed that one of your MIDI files caused a bad timing behavior of the sequencer and found + solved the reason for this as well (unnecessary SD Card accesses). -> all your MIDI files are played with stable timings now :) Best Regards, Thorsten.
sparx Posted January 7, 2012 Author Posted January 7, 2012 Thorsten, thank you so much, I can report that all files seem to be playing now. Regards S
