Hi to alll.
Perhaps be this one the solution.
This circuit I have tested it in my mb64 and works perfectly, with an encoder alps of 24 steps for turn detented.
They obtain 0 to 5 v in 128 steps .
Only I need to test in next days the circuit multiplier of frequency to obtain the same result in 64 and 32 steps.
I hope that  be useful for  you .
Dispense my bad use of English language.
gretings
FARIO
NOTE  :  this post is  also put  in MIDIbox HUIs  section     ( Pots *and* encoders in a MB64 or 64e?)
NOTE: single posting in the subject is enough. Otherwise forum becomes more cluttered and searching for a certain thread more difficult.
Thank You, Moebius
NOTE: I edited the dupe post in the HUI forum to point to this thread.
Best!
Smash
This looks interesting, but I'm really not sure what it's for.  If I understand it correctly, it uses an encoder to generate a 0-5v signal to connect to an AIN module....  but why?
hi to all
Yes moogah ,is a  potentiometer emulation, in order to be able to connect in a midibox 64 (not 64E) an encoder and to be able to utilize it with the 4 pot modes (normal ,snap,relative ,parallax) ,and also to use 4 lines LCD (4 X 20).
I attempted connecting encoders in my mb64, but I could not configure the software, it was working like two press buttons.
For that reason I looked for an hardware solution .
If you need more information ,notify me.
gretings
