liinnerd Posted September 25, 2006 Posted September 25, 2006 Currently I'm building a midibox64 and a 64e to create my own (xtra-large) ableton live controller.Now my problem (or dilemma) is that I need at least 160 buttons and almost every button needsit's own led to indicate if it's selected or not.I've already searched on the wiki and the forum for information about switch matrix's but it isn'tclear to me how to combine the leds and buttons in a matrix with the result that each led light's upwhen a button is pressed and sends out a midi CC to ableton. Another possibility and better way is to receive the button information from ableton. But still I don't understand how to achieve this effect. It's probably just all in the code, but maybe you can help me to clear up some things.thanks in advance.
moxi Posted September 25, 2006 Posted September 25, 2006 you have to build two matrix, one for the LEDs the other for the button..Another possibility and better way is to receive the button information from ableton. But still I don't understand how to achieve this effect.with the mb64 and 64E you can assign midi event to trig the LEDs within the serge's editor
liinnerd Posted September 27, 2006 Author Posted September 27, 2006 thnx for your reply. Now I have another question: When I build the button matrix, does every button really needs it's own diode like shown in the connection diagram ( http://www.ucapps.de/mbhp/mbhp_scan_matrix1.pdf ) ?And if so, which diode should I use. I assume an 1N4001 (100V, 1A) should be enough?
TK. Posted September 27, 2006 Posted September 27, 2006 The diodes prevent a short circuit when more than one button of the same row is pressed, so they are important.1N4001 is a little bit oversized, 1N4148's are fineBest Regards, Thorsten.
